05 v300,v330 91&93 smart maps
Does anyone know where I can find these maps at? (not at Vishnu)
v300 or v330 for 05 smart enabled
Plus, how do you disable smart sys, maybe I could use a non-smart map for now,
something is better than nothing
thanks in advance
thanks in advance
I have emailed Shiv asking for the 93 octane 2005 v300 (subzero). When I get it I'll post here. I found a thread earlier on this forum that has some 91 octane maps for subzero:
From Evo Kid
https://www.evolutionm.net/forums/sh...d.php?t=166216
From Evo Kid
Originally Posted by NEMES!S
I opened those maps w/ xmap 3.2 it doesn't recognize them it says some of the variables are unknown
I'll try it though
have you used them
I'll try it though
have you used them
Shiv said to use 0+ maps for 2005 zero and subzero here:
https://www.evolutionm.net/forums/sh...15#post2580615
EDIT: Of course my question was regarding non-smart, so I'm not sure if this applies to smart.
Adam
Adam
Adam
Adam
Here is a base 93 oct map for 05 w/smart_tables "0"ed
the smart tables are still there but have no effect or function,
the Ecu and base fuel and timing maps from the Xede are in control.
I put this map into a smart template & disabled smart
still seems a little rich.
Map no good
Map no good
Here's 03-04 with smart boost enabled other smart tables 0
all this is just a guess though!
this is also 93 oct.
Also no good
Ill try again
Also no good
Ill try again
GannerBoy
10
Mar 23, 2006 12:54 PM
