Is it normal for AFR's to lean out in cold weather?
Old Dec 9, 2005 | 02:24 PM
Jorge T's Avatar
For Houston 40*f is cold now my 11:1 AFRs changed to 11.8-12 is this normal?
I'm runing V3 SMART.
Old Dec 9, 2005 | 03:00 PM
donour's Avatar
This shouldn't happen. SMART should work to AFRs very close to the same level.
d
Old Dec 9, 2005 | 03:02 PM
shiv@vishnu's Avatar
Totally normal and totally acceptable. Less overfueling is necessary when conditions get cold since the engine becomes less knock prone (due to subsantially lower charge temps). However, you can adjust the amount of fuel offset the SMART system puts in to make it compensive for temp changes to a greater or lesser extent. To make it run richer in colder temps, but bigger postive fuel offets in the upper half of the SMART fuel table
Shiv
Old Dec 9, 2005 | 07:31 PM
donour's Avatar
Really? 0.5-0.8 points from ~72 to 40 degrees? My datalogs don't reflect this.
d
Old Dec 9, 2005 | 08:38 PM
Jorge T's Avatar
After the first to test runs I let the car sit for a while and went out again, AFRs got to 11.5-11.4. I presume this was due to the intake manifold getting heat soaked a bit. When I last checked my tune it was 80*f, afrs were 11s and the top of the cursor on the smart fuel table was at 0.
I have a big front mount that may be cooling too much in this 35-40* weather.
This is what SMART was trying to do.
I'll try Shiv's suggestion and fatten up the correction starting at .5 interpolating up to top cell value.
SMART is so cool!
Attached Thumbnails Is it normal for AFR's to lean out in cold weather?-1209051.jpg
Ozmi007
Nov 15, 2016 12:32 PM
asu11
36
Oct 15, 2016 12:25 PM
boyvang
Jul 16, 2015 07:17 AM
nytalonTSi
Apr 5, 2011 05:38 PM
Ph3n1x
Jan 19, 2008 04:25 PM
