Calculating airflow?
Old Dec 12, 2005 | 12:23 PM
Ludikraut's Avatar
Got a question ...
Can I calculate the amount of air flowing into my engine by looking at the MAF logs?
I am basically trying to figure out a way to calculate my engine's VE, for which I assume I will need to be able to calculate/log boost and airflow, correct?
l8r)
Old Dec 13, 2005 | 12:09 PM
Aby@MIL.SPEC's Avatar
I thought I saw a fomula within the s-afc forums to calculate airflow based off our maf reading.....
Old Dec 13, 2005 | 01:21 PM
donour's Avatar
Unless I am mistaken, MAF reading _is_ the amount (mass) of air flowing -- although you probably want to do a unit conversion to get it to kg/sec.
d
Old Dec 13, 2005 | 01:34 PM
Nez136's Avatar
hmm, thats a good question, but the Airflow is logged in loads which are always going to be different so you would have to do a couple runs in 3rd gear or so and average your data before you can do the equation...somebody correct me if im wrong
nevermind im confusing myself
Old Dec 14, 2005 | 01:41 PM
Ludikraut's Avatar
d
You wouldn't happen to know what units the MAF measures in?
To calculate my VE, I'm thinking that I will still need to log boost along with MAF though, because, for example:
if 100% VE, 2.0l block, 5000 rpm, 19 psi equals to 405 cfm
then measuring 365 cfm with the same setup (2.0l, 5000 rpm, 19 psi) should mean that I am actually operating at 90% VE, correct?
l8r)
PS.: the above calculation may be slightly off ... too lazy to double-check if I used the right conversion value for PSI.
Old Dec 14, 2005 | 01:46 PM
Nez136's Avatar
the MAF measures in Hz
Old Dec 14, 2005 | 01:59 PM
Ludikraut's Avatar
So does anyone have a conversion table for the stock MAF? I.e. something like 1000 Hz = xxx cfm (or whatever units).
Shiv must have something like this, otherwise how would they know how much to adjust the MAF signal...
l8r)
Old Dec 14, 2005 | 02:06 PM
Nez136's Avatar
Accually you might be better asking the guys from TTP or Full Throttle b/c they use the MAFTPRO which calculates VE
Old Dec 17, 2005 | 07:31 AM
gunzo's Avatar
ludi, try hz*0.32 for est. cfm
got the number off stealth316.com (i think) and it match quite closely to my estimated flow at boost for my engine
