Boost Compensation - Possible Implementation
Old Feb 16, 2006 | 05:32 PM
  #61
freedom's Avatar
Originally Posted by Evo23IG
Is Shiv incorperating this into the new stuff he is working on or does he atleast approve of it? Is this something we get from you or Vishnu?
To be honest I think that is the case. Shiv and I haven't communicated in over a week. That said I was a week late in getting the manual written and only finished it on Wednesday of this week.
Originally Posted by Donour
PPS- What input are you using now for MAP? I want to add it to pyxede. I just realized it's been 5 months since the last version and there's lots of features in the development branch that nobody has even seen.
The module uses the Xede's PWM0 as the input in both modes. Thus depending on the mode that the module is operating in the translation is different (e.g. temp or vehicle speed.) I'm still going to hold off on release these until we get through the big temperature swing this weekend. It is predicted that we will see sub-zero temps on Friday night. PM your email address to me and I'll send you the manual ASAP with more to follow next week.
Originally Posted by Ludikraut
Sign me up for one .
Also PM your email address and I'll send the manual. I would like feedback...
Old Feb 16, 2006 | 05:43 PM
  #62
Ludikraut's Avatar
Dang and here I thought my documentation review days were over ... j/k
PM sent.
l8r)
Old Feb 16, 2006 | 06:09 PM
  #63
sandm's Avatar
I would be interested in one as well. temp's here vary from 30 deg. in the winter to 105 on a hot day in the summer, and I only want the lc, not interested in the nls feature. looks to be a great product.
Old Feb 16, 2006 | 10:01 PM
  #64
Rushin's Avatar
I'd definitely like to have LC without NLS. I need more wires behind the glove box...
Old Feb 28, 2006 | 09:40 AM
  #65
SuperHatch's Avatar
bump... updates?
Also, after reading through this thread again... if you have boost compensation, how do you actually set your boost? How does the Xede know what to do with the PWM input? I don't fully understand the logic behind this. Does the box have a memory of what the boost was the day you installed it, and it will output offsets from that point on when the weather changes?
Old Feb 28, 2006 | 05:45 PM
  #66
freedom's Avatar
PM me your email address and I'll send you the full manual as it is too large to attach here.
I attached the explanation of how the module works with the Xede for boost comp. Sorry for the four zip's pdf pages, but that is the only way I could get them to post given the size limit of 100k per file.
I think that the manual pages should be helpful, but I'll give direct feedback here.
Boost is still set by modifying the normal smart boost map. The module only compensates for environmental changes such that what is in the boost map applies for any temp, etc. I wanted to hold on to as much of the Xede's way of doing things to make things easy for people.
The PWM input is just another input for the Xede which to the user is represented as a value between 0 and 100 percent. Instead of a voltage, pwm represents the value as the percent of time that the signal is at 5v versus 0v. Thus if the pwm input to the Xede is 0v all the time, the pwm value is 0%. If the signal is 0v for say 1 second and 5v for 1 second, then the pwm value is 50%. And so on. Note that the time periods quoted are only an example. The real numbers are much smaller. Also note that the period of time is doesn't matter, only the ratio.
There is no memory in the implementation. I wanted to keep the thing as simple as possible. Basically the offsets are from the baseline map. In the attached pages are offsets are for a map that is baselined for ~70F. In other words it should work for the maps which Vishnu has on their web site.
And the update question... I built up ten units plus extras and they have been sitting around for several weeks. Shiv and I talked about selling them through Vishnu several weeks ago, but we haven't touched base given everything that has been going on (e.g. I got busy and he went on a trip.)
Originally Posted by SuperHatch
bump... updates?
Old Feb 28, 2006 | 07:32 PM
  #67
SuperHatch's Avatar
While I understand how it should work, I'm still not sure HOW it works.
The SMART boost table is simply solenoid duty cycly in a table of RPM vrs. load. Your box shoots for a target load at each RPM rather than a target solenoid duty. I don't know, I need time to digest this and try to sort it out before I post more stuff that really probably makes no sense.
Old Mar 1, 2006 | 04:49 AM
  #68
freedom's Avatar
The box modifies the solenoid duty cycle as a function of the measured environmental conditions. And it does that by applying different scaling factors from a table where the scaling factor is chosen based upon the measured temp/pressure values.
Old Mar 1, 2006 | 05:26 AM
  #69
SuperHatch's Avatar
After reading the pages of the manual that you posted, this makes a lot more sense.
When can I get my hands on one?
Old Mar 18, 2006 | 09:44 AM
  #70
954DRGSR's Avatar
Really Interesting
Bizzump.
Old Mar 18, 2006 | 10:01 AM
  #71
David@Vishnu's Avatar
Hi guys,
Freedom sent me 3 units to test the other day. We hope to get thim installed in Dustin's car this week and will report back with results
Old Mar 28, 2006 | 04:24 PM
  #72
WhiteEvo05's Avatar
Any news from the mothership about the performance of the boost compensation module?
Old Mar 28, 2006 | 08:59 PM
  #73
Agent-Smith's Avatar
God. Just Finished reading this whole thing. Absolutly amazing work.
I can tinker around with computers & software all day long (programmer). But I really want to know how to make my stuff have stuff happen in the real world.
Somebody teach me! (aka freedom!)
Old May 14, 2006 | 09:05 AM
  #74
freedom's Avatar
A quick update on this project. In short I'm stll trying to find a way of selling these modules in a manner that doesn't require paying the site for vendor status at a rate where the fee exceeds the profits on the module.
Old Jul 18, 2006 | 09:37 AM
  #75
Evo23IG's Avatar
Was always interested in this product, any updates???
