Any idea Vishnu guru's
Old Jan 13, 2006 | 09:31 PM
EidolaDream's Avatar
Link
Andrew and I seem to be a bit of a hault.
Old Jan 14, 2006 | 08:22 AM
I have a question I hope maybe someone could answer.. To double check on the turbo itself, Does anyone know the spec's (size wise) on Vishnu's GT3037 turbos?
Below is what I got from Full-Race on the turbo specs.
Compressor Specifications:
-56 trim GT37 series compressor wheel with a max flow rate of 53 lb/min
-0.60 AR ported shroud compressor housing
Turbine Specifications:
-84 trim GT series turbine wheel
-0.63 T25 turbine housing
-Steel ball bearing center section.
