Tales from the Dyno: Sti turns up the torque!
05 STi with just an intake and exhaust
With and without a custom tuned Reflash
91oct
WHP and Torque:
AFR and Boost:
91oct
WHP and Torque:
AFR and Boost:
Originally Posted by shiv@vishnu
Yeah. But stock EVOs run similarly rich. And you have on of those, don't you??
Originally Posted by housedj
where did you get that from? i am aware that stock evos run AFR's in the low10 to high 9 range.
Shiv interputed your statment the same.
i have 2 evos actually. i just figured that if 1 graph was tuned, that the AFR would be flat at 11.5:1 especially on 91. you guys can get more power out of it & still have no detonation...
Thanks, Shiv for posting about STIs for us defectors
Anyway, just looking at the graph, it seems like in this and other charts the upper RPMs falls off a lot faster after the tune compared to pre-tune. Not knocking the results, they are great. Just wondering if it is harder/less safe to get similar gains say from 5700 RPMs up. I am just comparing the downward slope of the pre- & post-tune charts.
Thanks!
Thanks!
One more question for Shiv. Are aftermarket intakes less/more/same effectiveness on an STI vs. Evo? I know you aren't a fan of replacing the stocker on the Evo, wondering if that opinion holds for the STI.
Thanks!
Thanks!
- Steve
P.S. - The reason the torque is so massive is for a few reasons. The compressor can move more air in the lower RPM ranges allowing greater midrange boost and torque. Also, at lower engine speeds the cooling system is more effective in cooling the combustion chambers, this allows a more aggressive tune in that area without increasing risk substantially.
Nice job Shiv.
Originally Posted by NoTec
Umm. not tryin to be a wise *** here but if he tunes for 11.5:1 what happens to his safety margin??? Oh right its gone and the Sti owner has to buy a new engine if he gets a bad tank of gas or the environment in which he operates the vehicle changes. Did we not see Stews (God help him) ordeal with that mail in flash with the lean conditions. Dont know if you intended it to sound this was but it looks like your giving advise to a Master Tuner.
