Guess what this is and how it is significant?
Old Mar 12, 2006 | 05:46 PM
Smogrunner's Avatar
Old Mar 12, 2006 | 05:51 PM
Smogrunner's Avatar
More... (my time is in the left column)
Old Mar 12, 2006 | 06:00 PM
Smogrunner's Avatar
hint: it is oem and it makes gas leave the fuel tank
Old Mar 12, 2006 | 06:01 PM
Noize's Avatar
EvoM Administrator
Low tapering boost. Stock 16G with a 9.8 hotside back in the day.
The run numbers are low, so I'd say you were a stage zero or one? Crappy 60'.
shiv@vishnu's Avatar
They had digital cameras in 1980?
shiv
Old Mar 12, 2006 | 06:44 PM
Smogrunner's Avatar
Modifications: Vishnu Stage 1. Full exhaust WITH cat, Xede, cam gears set at -5, full weight. STOCK FUEL PUMP.
Old Mar 12, 2006 | 06:47 PM
jj_008's Avatar
No way that was with the stock fuel pump. Your motor would have had a catastrophic event .
Old Mar 12, 2006 | 06:58 PM
jkim2001's Avatar
shiv
I was thinking the same thing.
Old Mar 12, 2006 | 07:03 PM
Noize's Avatar
EvoM Administrator
STOCK FUEL PUMP.
Stage 1+ at altitude is when the stocker starts needing to be upgraded AFAIK. You were on stock cams at sea level, yes? OEM pump can handle that with ease IMO.
Old Mar 12, 2006 | 07:50 PM
Erik@MIL.SPEC's Avatar
I don't think we have sea level tracks here in SoCal.
Old Mar 12, 2006 | 07:57 PM
EvoTio's Avatar
That run that Smogrunner made was at the now defunct Carlsbad Dragstrip. The dragstrip was at about 600' above sea leval. BTW Carlsbad was notorious for never having up to date timeslips. I think all of the timeslips I had when I raced there were dated 1980 .
Old Mar 12, 2006 | 08:05 PM
Noize's Avatar
EvoM Administrator
Sorry, when I say sea level, I mean not great altitude, like in CO or someplace where the air is more thin like 3500' plus where you could overrun the stock pump easier. Our track is at 480' here, and nowhere near of overrunning the stock pump with a stage 1 car.
Old Mar 12, 2006 | 08:23 PM
Drews_WRX's Avatar
it is significant because it shows your amateur drag racing skills ....110.97mph should have been good for a 12.4 run.
Old Mar 12, 2006 | 10:07 PM
vanisher's Avatar
All to save $80? .. hmm
Old Mar 12, 2006 | 10:20 PM
RazorLab's Avatar
That's unpossible!1!!! Everyone knows the stock fuel pump shoots to 12.1+ AFR up top!
