How to tune the Timing with the Xede (SMART) ?
Old Mar 13, 2006 | 11:41 AM
RREvo's Avatar
Question How to tune the Timing with the Xede (SMART) ?
Hey guys how do you tune Timing with the Xede (SMART), I tuned the A/R for 11. but am not sure what is the best way to tune Timing any advise would be appreciated thanks.
Old Mar 13, 2006 | 11:53 AM
Agent-Smith's Avatar
Uh. I would recommend getting a book and reading. Start with the highest stage on shivs maps for now?
Old Mar 13, 2006 | 03:59 PM
jj_008's Avatar
Start adding timing in .5 increments and watch the SMART timing table like a hawk. You have to remember that when you take out fuel you add timing advance.
Old Mar 13, 2006 | 07:15 PM
RREvo's Avatar
Ok jj 008 where do I start?
Old Mar 13, 2006 | 07:46 PM
jj_008's Avatar
For pump gas, I zero'd out the whole timing map from 0-4500rpm and from 4500-8000rpm I put in -1. That will be a good starting point. You'll find that you can add positive timing in the 0-4000rpm range. I never had a value over 2 since I was pulling out so much fuel in those ranges. In the upper RPM (5500-8000) range you "probably" will never have a positive number.
Old Mar 15, 2006 | 01:57 PM
RREvo's Avatar
Hey jj 008 I did the like you suggested zeroed out the Timing till 4000rpm’ and I put -1.5 from 4500-8000rpm’s and I noticed that I have more lag that way, before it hit around 4000rpm’s and now it hits around 5000rpm’s so what do you think could that make such difference in spool, below are my maps the GT35RKec is my old map and the GT35R0Timing is my new map so let me know what do you think thanks.
File Type: zip
File Type: zip
Old Mar 15, 2006 | 02:06 PM
jj_008's Avatar
I don't have Xmap at work, but what values did you have in there before in the 0-4000rpm range? Were they positive, negative, or just zero'd out? Did you have any knock activity? I will take a look at your maps when I get home.
Old Mar 15, 2006 | 02:12 PM
RREvo's Avatar
Hi I had it zeroed out till 3500 thanks for a prompt answer and how are you 100% certain that you don’t have a knock?
Old Mar 15, 2006 | 02:17 PM
jj_008's Avatar
If your SMART timing is going into the negative region then you are getting knock. If not, then you are OK.
Old Mar 15, 2006 | 02:22 PM
RREvo's Avatar
Than I am fine
Old Mar 15, 2006 | 05:45 PM
jj_008's Avatar
Your map looks like a much better starting point since you pulling out so much fuel. There shouldn't be a spool up difference between the 2 unless there is some knock events going on. I say go with what works .
Old Mar 15, 2006 | 07:41 PM
RREvo's Avatar
thanks jj 008
Old Apr 24, 2006 | 06:12 PM
yesevo's Avatar
so with xede smart....you can adjust ecu real engine timing>?
Old Apr 24, 2006 | 06:24 PM
jj_008's Avatar
The XEDE allows you to adjust timing w/o SMART. SMART allows the XEDE to make real time fuel and timing adjustments.
Old Apr 25, 2006 | 07:47 AM
yesevo's Avatar
im going to buy one...i already got dynoflash street tune.... and i just wanna fine tunning with xede,,, or should i buy safc?
