i need a v2 330+ map for a n 05 93 oct
Old Apr 1, 2006 | 04:23 PM
shiv@vishnu's Avatar
Without a map and the ignition ON, it should be solid red. This is a rare sight because XEDEs usually have maps in them (except after a firmware update possibly).
Old Apr 1, 2006 | 04:27 PM
evo-boy's Avatar
yes its solid red wich leads me to belive its my cable that is causing the prob and not the xede connection. thanks for the help
Old Apr 1, 2006 | 05:11 PM
evo-boy's Avatar
if its red that means there is no map so i could drive with it right and boost etc?
Old Apr 1, 2006 | 06:25 PM
evo-boy's Avatar
it now says store error when i upload the map onto the xede, anything helps
i got it working..... i think the AFR's seem to start off a bit high but they go down to about the right amount also there is a huge difference between the lower and higher RPM rang, and there is some strange clicking sound only when i hit or pass 0 BAR
