i need a v2 330+ map for a n 05 93 oct
Originally Posted by evo-boy
just what the title says, p.s. i need it soon if anyone can help
https://www.evolutionm.net/forums/sh...d.php?t=191960
Just make sure peak boost is in the 21-22psi range. You might have to adjust the boost table a little bit.
That's fine. But you will have to adjust the boost table a bit. You can also try the other Stg 0+ map as it was for a car with a free flow cat like yours. However, it is running SMART so you would have to zero out the SMART fuel and SMART timing tables. Easy as that!
-shiv
-shiv
i tried to connect to the xede and was not getting any indication that the laptop and xede were communicating, but as its getting late i think i am going to fix it in the mourning or afternoon. Any advice would help a bunch thanks
It should communicate no problem.. esp if your laptop has a serial port. If it's USB, and ur using a USB->serial converter, some brands have been known to cause problems. The one we recommend is from IO Gear. It works and it's the cheapest.
i have v2 but the map i need of the vishnu site will not work, i dont know why
thanks for the help so far, i had to drive my murcury mount and it sucks i miss my evo after one day of notdriving it, hopfully i get it running this afternoon
