Xede/Xede flash Dynoed. Meth NOT dynoed. A ??
Old Apr 17, 2006 | 04:45 PM
  #31
smokedmustang's Avatar
Originally Posted by EvilBlueEvo8
oh yeah i forgot this. when looking at your picture of setting up the xede to control the alky controller, it shows pin four on the black plug going to the controller. but if you look at the pinouts on xmap 3.2, you see that pin 4 on the black plug is crank in. according to the map setup, drive output one controls the alky controller. isn't that pin 7 on the black plug?
Good question, I didn't hook it up yet!! Maybe I should know this first? Thanks for the great info guys, WE all appreciate it!!
Old Apr 17, 2006 | 06:27 PM
  #32
EvilBlueEvo8's Avatar
hey smoked, have you noticed there wasn't any meth map? or that he stated that his meth map was not using the smart timing, but there is a smart timing map with values? i pm'd him to see if he could post the answers here for others to read.
Old Apr 17, 2006 | 06:39 PM
  #33
Thanks!! I didn't notice, due to my computer ineptness!!! I am getting my Meth kit back this week, and I was going to mess with it then. I think if we mention Al and Shiv in the same sentence, Shiv will answer this!! he must do a search, and see if their names are in the same sentence!!
Old Apr 17, 2006 | 08:04 PM
  #34
Cajun Power's Avatar
That is too funny. I'm going out to my car and physically check the pin and I'll make sure the 93+meth is posted.
Gimme a minute.
OK, i'm back...
Pin 3 Grey connector. Here is what is on the connector.
Pin
1 Red wire to serial port
2 Dark Green to ECU
3 Green ALKY CONTROL
4 Black to serial port
5 White to ECU
6 Black to ECU
OK - the map. The table are called SMART timing but they are just the regular timing. It is NOT SMART Enabled. Attached.
How's that? I corrected the activation LED wiring and the NLTS and ALKY outputs.
Attached Thumbnails Xede/Xede flash Dynoed. Meth NOT dynoed. A ??-vishnu-xede-ams-meth-nlts-remote-led-v4.jpg
File Type: zip
Old Apr 18, 2006 | 02:51 AM
  #35
Gimme a minute.
OK, i'm back...
Pin
2 Dark Green to ECU
5 White to ECU
6 Black to ECU
You da man!! Thanks!
Old Apr 18, 2006 | 05:21 AM
  #36
awesome stuff here. its great that the 3 of us are all doing the same sort of setup. we can really learn from each other and push the envelope while helping shiv out. sticky this thread already!
Old Apr 18, 2006 | 05:47 AM
  #37
Agree, this will help the fellow Vishnuites coming up behind us!!
Old Apr 18, 2006 | 08:33 AM
  #38
I also wanted to add what Cajun sent me about his cam/timing setup:
"I run the 264I 272E at -2 -2. I was running -3 -3 which made smoother power but the -2 -2 made a bit more at the peak.
There was some testing done with 246/272, 264/264, 272/272, 272/264 and they all made the same power when set at the same -2 -2. So 264 and 272 are equal or VERY close in gains. The 280 cams are a difference."
Old Apr 18, 2006 | 03:53 PM
  #39
is anyone else having trouble seeing the methanol map? i'm talking about the actual box that you see values in (just like boost, timing, etc). according to that map index box that pops up with the maps when you open the file, there should be 5 maps. timing, smart timing, boost, fuel, and methanol. i see the first 4. also there is a methanol button under the black box on the main screen where the live data displays, but if i click on it, it doesn't launch anything unlike the other four buttons. i look under the water spray function in the drop down menu and it looks like it is correct. i'm confused as to why i can't see this map. anyone? cajun???
Old Apr 18, 2006 | 08:21 PM
  #40
I see it...
Attached Thumbnails Xede/Xede flash Dynoed. Meth NOT dynoed. A ??-meth-map.jpg
Old Apr 19, 2006 | 05:35 AM
  #41
I see it...
hey chris, is there anything else that you have to do to the xmap. i'm opening the map with 3.2 just like you. i have the map listed in the configuration setting box like you. i also have that methanol button just like you, but i can't get the actual 20X20 box with the values to show. you have it on you screen in that pic so i must be doing something wrong or have something set wrong. any clue? i've never had problems with xmap and maps before.
Old Apr 19, 2006 | 05:50 PM
  #42
just want to update you guys. i did finally get the meth grid to open up. it will not open with the rest of the maps when i open the whole map initially with xmap 3.2. for some reason if i go to the maps tab on xmap and then click on tile, it pops up. i can also just hit f10 and it shows up. after that i can click on the methanol button on xmap and it opens just fine. i can also close all the maps and click on view all maps and it will show up with the rest of them. i have no clue why it does this. i'm just happy i can see it now.
Old Apr 20, 2006 | 06:14 AM
  #43
You want to know what it is.... this is a good one. I bet you have the windows task bar where it does not autohide. the Meth map is in the bottom left corner and if you task bar stays up you won't see it. If you enable autohide, you'll probably see it.
Now wouldn't you feel dumb if that was the case... HAHA.
Old Apr 20, 2006 | 07:23 AM
  #44
lol. thats good. i bet you your right. i'd have to check that out cause i don't have the taskbar on autohide. be funny if it was the cause. it sure would explain why the methanol button wasn't working. if i couldn't see it, i couldn't close it. so why would clicking the button open something that was already open? lol. i'll try it when i get home and let you know.
Old Apr 20, 2006 | 03:57 PM
  #45
you are absolutely right! it was hidden under the task bar. why the heck does it do that? that is so strange. at least i have a workaround. lol.
