Knock Light Implementation
Old Apr 27, 2006 | 07:23 PM
freedom's Avatar
I read the title of another thread and thought it was about creating a knock light function with the Xede...
Assuming one has the SMART system it occurs to me that one can program the water spray output to permit turning on the MIL when knock is detected by setting,
Control source = an0in
RPM >= 3500 (this is arbitrary but seems like a good number to start with)
Control >= 40 (my experience suggests that this would filter out random junk)
Once started stay on for = 5 (again arbitrary, but one would like to see the problem)
Stay off for = .1 (something minimum)
Then the water spray output of the Xede can be tied to the MIL light at the ECU, as ground the pin at the ECU turns the light on. This works as the Xede ground the water spray output when the function is active.
Note that I haven't tested this but its a good bet that it would work
Old Apr 28, 2006 | 02:08 PM
donour's Avatar
Good idea, but wouldn't that disable the MIL's "legitimate" uses?
d
Old Apr 28, 2006 | 04:20 PM
freedom's Avatar
I don't think so because...
The MIL light is activated by the ECU via grounding the light within the ECU. In other words the other side of the light is +12v. Thus by connecting the Xede's water spray output to the ECU MIL light pin, either the Xede or ECU can activate the light (e.g. wired or).
Futher as the Xede would only flash the light when knock is present versus when the ECU activates the light it is on until reset, one can tell the difference between knock and when the ECU throws a MIL condition.
In short one can get this functionality by simply adding a wire from the Xede's water spray output to the ECU MIL pin. Then simply change the Xede's water spray conditions as cited above.
Basically I'm 90% sure this will work. The only question is if the Xede will respond to the short pulse represented by the knock condition. If the Xede doesn't process the water spray conditional every at the normal 100 hertz, then it might miss a knock state. That is really the only question on my mind at this juncture.
If someone is interested in this I could document this further or push a bit testing it with fake data (e.g. set to trigger at a lower threshold, or engine noise).
d
Old May 1, 2006 | 02:12 PM
Ludikraut's Avatar
Erm ... cough ... what does MIL stand for? (and don't say Mom I'd Like...)
l8r)
Old May 1, 2006 | 03:46 PM
freedom's Avatar
Malfunction Indicator Lamp
l8r)
Old May 1, 2006 | 04:37 PM
SuperHatch's Avatar
MIL, SES, CEL = same thing
Service Engine Soon
Check Engine Light
freedom's the man
Old May 1, 2006 | 06:08 PM
donour's Avatar
MIL is the name that the SAE gives to the light in their official specs. People (and automotive companies) call it lots of different things, but in the actual OBD-II documents it's MIL.
And for future reference, ecu codes are called DTCs (Diagnostic Trouble codes). We usually only talk about the powertrain ones (Pxxxx), but theres also a an entire set for transmissions and chassis malfunctions.
d
Old Aug 10, 2006 | 08:33 PM
alan678's Avatar
I know its an old thread...but is this still in the works or did it just die out???
Old Aug 11, 2006 | 01:02 AM
Vishnu_Evo8's Avatar
that would have been pretty cool.
Old Aug 11, 2006 | 05:30 AM
freedom's Avatar
I didn't see any interest so I didn't do any more about it.
This is a one wire addition. Basically a connection from the Xede to the CEL / MIL light at the ECU.
Old Aug 11, 2006 | 08:10 AM
EvoTio's Avatar
This is the first time I've seen this thread. I would be very interested in this feature.
Old Aug 11, 2006 | 08:54 AM
NEMES!S's Avatar
same here
couldn't you get the same effect with a LED
Old Aug 11, 2006 | 09:48 AM
Erik@MIL.SPEC's Avatar
ditto on the interest
Old Aug 11, 2006 | 01:10 PM
alan678's Avatar
Interested here...thats why i brought it up... :-)
Old Aug 11, 2006 | 06:32 PM
freedom's Avatar
Sure but then you would need to find somewhere to mount the LED.
In any case I'll write up instructions this weekend and post it.
