Hey Shiv, Tune This . . .
Originally Posted by Ted B
the valves are pneumatically operated (look mom, no cams).
Originally Posted by scorke
^ They have no cams, Scorke
Check this link...http://www.formula1.com/insight/rule...gs/14/485.html
limited to not only have cams but they are not allowed to even use variable valve timing (MIVEC)
http://www.scarbsf1.com/
and then
http://scarbsf1.com/valves.html
press control f then camless ot find it from the first link.
Scorke
and then
Scorke
[snip]"Renault have not planned an Electro-mechanical system, which was commonly believed to use actively controlled magnetic coils to open and close the valves. Clearly the electrical and RPM performance required from the this system were not ready or suitable for a F1 engine. "[/snip]
Now I know why the Renault engine is better than the Cosworth. Better tell those Cosworth gus to work with the lights on, kindda helps to see what you're going and stuff.
and then
Scorke
and then
Scorke
