I got tuned*Updated w/Graph...
Old Aug 12, 2006 | 10:56 AM
  #31
jrsimon27's Avatar
alan678 did you asked alfred as to why shivs off the shelfmaps are lean??
Old Aug 12, 2006 | 11:11 AM
  #32
Erik@MIL.SPEC's Avatar
I dynoed right after EvoTio on that day in July 2005 and I put down 306/306 on 91 and 340/330 on 100. It was at least 90 degrees. This is on stock cams. The thing that may have helped me is that Shiv said my car was unusually quiet. Alfred noticed that whereas most Evos are pulling 4 degrees of timing up top, I am pulling only 1.6 at most.
Old Aug 12, 2006 | 11:18 AM
  #33
alan678's Avatar
no...i didnt...
Old Aug 12, 2006 | 12:28 PM
  #34
nj1266's Avatar
Guys,
If the dyno chart that you posted is CORRECTED, then the high temps are eliminated as variables. If you look at the charts posted by snoop then you will see an STD correction factor of 1.03.
That means that his real hp on that day at that time is 290 whp and 297 tq on the first sheet he posted.
Please stop saying that heat was a factor and then post CORRECTED dyno sheets. This is flat out not true. If you want to say that heat was a factor, then post UNCORRECTED dyno sheets. You CANNOT have it both ways.
Old Aug 12, 2006 | 12:58 PM
  #35
SiCKlEyWiKeD's Avatar
snoop in your 91 dyno pull your afrs seem to be close to 12.0 all the way it seems thats how shiv likes it.
IMO that is very agressive for 91.
Also, I think a lot of people are forgetting about the hellish weather cali has been having. Everyone is comparing their numbers to eveyone else. Remember it's common sense that weather plays a huge factor in our cars.
Old Aug 12, 2006 | 01:15 PM
  #36
Spec'd's Avatar
Mods please delete this.
Old Aug 12, 2006 | 01:17 PM
  #37
Spec'd's Avatar
+1
Old Aug 12, 2006 | 02:31 PM
  #38
alan678's Avatar
Originally Posted by Spec'd
Another +1
Nope didnt ask...
Originally Posted by nj1266
Guys,
Gotcha...
My UNCORRECTED max values were 289 WHP and 264 TQ...
BTW how do correction values work??? My chart was corrected at 1.06 with the high temps and snoop was at 1.03 with his fairly low temps...
Old Aug 12, 2006 | 02:55 PM
  #39
Spec'd's Avatar
All in all, it's definetly an improvement.
Old Aug 12, 2006 | 03:41 PM
  #40
nj1266's Avatar
Originally Posted by alan678
Nope didnt ask...
Gotcha...
BTW how do correction values work??? ..
I do not know how the different correction factors are arrived at. There are so many of them. The most commonly used are SAE and STD. They basically form a base for temp, barometric pressure, humidity and that base is compared to all real world numbers that are experienced on the dyno.
So if you dyno on a hot day with high humidity and get 280 whp, your corrected numbers will be HIGHER since atmospheric conditions that you are comparing your number to are lower.
The best practice is to quote uncorrected numbers if you are NOT comparing your power to the power of another Evo with the same mods on the same dyno. But if you are comparing your numbers to another Evo with the same mods on the same dyno that dynoed on a different day, then it is BEST to quote corrected numbers.
In this thread it is good to quote CORRECTED numbers so we can tell you what other Evos with similar mods to your put down on the same dyno. That is what I and other have done even though my evo does not have cams but still put corrected numbers similar to yours.
The reason for this is that snoop's numbers are closer to the base STD correction factor than yours are. That is why a larger correction factor is applied to your chart than his. You dynoed on a hotter day than he dynoed at. If you dynoed on a day that has the exact same atmospheric conditions as the STD base numbers then your correction factor will be 1. Basically, no correction needed, but that is very rare.
Old Aug 12, 2006 | 03:47 PM
  #41
nj1266's Avatar
Weather plays a role if you are quoting UNCORRECTED dyno numbers. Corrected numbers are being posted, so weather is taken out of the equation.
Old Aug 12, 2006 | 07:36 PM
  #42
Jeff_Jeske's Avatar
What do you mean dude???
What I'm looking at is the -5 degrees or there abouts up top. One degree of timing up top is worth nearly 10HP.
Old Aug 14, 2006 | 10:14 PM
  #43
alan678's Avatar
What is a good cam gear timing combo for 272 intake/264 exhaust cam combo? Do u think having both gears at -3 with this cam combo is hurting me and is causing my wierd timing map?
Old Aug 15, 2006 | 12:18 PM
  #44
Jeff_Jeske's Avatar
Looking at the blue line on your dyno you can see that you were getting knock. This was probably due to being very lean. It appears that your tuner pulled additional timing and added fuel at the problem spots. This may be safe but in reality adding fuel alone probably would have done the trick as a richer mixture takes away some timing.
I highly doubt its due to the cam gears. Your CGs are set up for midrange power not top end power.
It would have been neat to see your baseline with the vishu map. Then correct the AFR on that map (do not touch timing) and compare the two. I bet they would be nearly identical but without the knock at 5600, 6400, and 6700 rpm.
In the end you picked up HP and made the car much safer. Basically you have a very safe pump gas tune. Now you can add race gas. With boost and timing maxed out your car will FLIPPING RIP!
Old Sep 9, 2006 | 10:24 PM
  #45
Evo IX MR's Avatar
Alan's car is very quick. Its pretty impressive to know that with a few little things sorted out you'll have 320 whp. Go catless and get it retuned.
