Still having boost problems
Originally Posted by Cajun Power
if you had a mbc and went to an xede you could be missing the boost pill by the watsegate.
i have a tee system that alows me to go back to stock config (with the pill and stock vac hoses) then back to MBC
Originally Posted by fishing_ndw
Have you replaced your lower intercooler pipe vacuum hose? The one off the nipple of lower intercooler pipe on the intercooler. There is a pill in that hose that needs to remain. Otherwise you will only see wastegate pressure.
Hope this helps....
Hope this helps....
Thanks to everyone
Originally Posted by NEMES!S
yes it still works good w/MBC
and it does turn green
3.207 I think is the firmware
standard 05 v360 93 smart enabled map off the web site
It runs great execpt for boost control
and you're "T" in the vacuum lines isn't FUBAR, then you need to send the Xede to Vishnu.
Originally Posted by atlvalet
All buyers should consider their options before purchasing. 100 bucks for XEDE flash is a marginal expense at best. Open your own business and give away the farm for all I care, but don't complain about something you knew about beforehand. And do your due diligence.
Originally Posted by dude
As long as you tapped this wire
Tee is good,
that is the wire, tried it many times
Have you had a chance to hook a lap top up to the Xede, go in to live data, and watch to see if the wastegate duty cycle changes or stays static? Have you ohmed out the coil of the wastegate solenoid to see if perhaps it is shorted or an open circuit?
I have tried 3 stock boost sol. none work
Do you have access to a meter that shows duty cycle (basically measures Hz...) and tapped it in the wire by the solenoid to see if there actually a signal at the solenoid...might be a broken wire in the harness.
yes I have an oscilloscope & multimeter
Are you talking about the XEDE harness? The boost sol works perfectly in the stock configuration, so I believe the stock harness is OK
