? on Evo IX V380
Old Oct 14, 2006 | 10:41 AM
  #31
tuffguy's Avatar
You'd still have to buy a cable ($90) on top of the $750 and program it yourself or take it elsewhere. That's assuming that you have a laptop.
Old Oct 14, 2006 | 11:18 AM
  #32
mrfred's Avatar
Yeah, the Vishnu flash was pricey, but it seemed like the best choice. I guess I consider the $90 cable as being a pre-modding necessary add-on like installing a boost gauge.
Old Oct 16, 2006 | 08:07 PM
  #33
Vishnu_Evo8's Avatar
Iv seen 4+ car length differences between stock 9s and my friends v380.
Old Oct 16, 2006 | 09:11 PM
  #34
Jaylenospoolboy's Avatar
Originally Posted by tuffguy
He thought that he felt more power too after the flash. Needless to say, he wasn't happy after we raced, so he had it looked at. There's nothing wrong with it.
And on top of that, Shiv locks the ECUs so you can't go anywhere else. Once you get it flashed by them, you have to go back to them.
No way!
He locks the ECU's? Where did you hear that?
Old Oct 18, 2006 | 07:36 PM
  #35
brp's Avatar
brp
when you order this stage WITH THE XEDE, i know you have to send the ECU in to get flashed, my question is what exactly do they do to the ECU alone? do they just raise the rev limiter or what???
Old Oct 19, 2006 | 09:56 PM
  #36
SHIFTT IX MR's Avatar
im also interest in this, and, what is the difference between the works flash and this flash? also, since im new to flashes, working with stand alones mainly, is it literally as simply sending in my ECU, and then getting it back a couple days later? since i live in south florida, how will this flash work with my surrounding area? will the ecu be able to adjust accordingly, as a stock flash world?
john
Old Oct 22, 2006 | 08:31 PM
  #37
yldMr2006's Avatar
stock evo IX mr se with just a v380 flash
DYNOED TODAY USING MUSTANG DYNO@EIP
test run=10/22/06
11:35 am
MAX power= 257.4 hp @ 6750 rpm
MAX torque= 273.9 @4250 rpm
Old Oct 24, 2006 | 06:26 PM
  #38
mike127's Avatar
were you happy with your gains? 30 hp @ the wheels isn't bad but it's not quite 50 as others have mentioned. Considering the reflash myself.
mike
Old Oct 24, 2006 | 06:48 PM
  #39
yldMr2006's Avatar
yes i'm happy with it.. but crave for more power so i'm planning to add downpipe , high flow cat and exhaust... see how Much power gain a tbe will produce...
Old Oct 26, 2006 | 01:45 AM
  #40
osunick's Avatar
It's not just the rev limiter... they can change the fuel, timing, and boost as well. I suppose it's not as adaptable as the XEDE but they can still do a lot.
Old Oct 27, 2006 | 09:04 PM
  #41
joshesh's Avatar
Compared to other ECU flashes, this Vishnu flash seems a bit expensive.
Is this flash the best value and worth the extra money compared to others offering ECU flashes?
30WHP isnt that much gain compared to an average 20WHP from a 50 buck map by Jestr.
50 sounds worth the money though, so what is the acual gain?
Old Oct 31, 2006 | 05:47 PM
  #42
res04's Avatar
I have over 15,000m on my IX custom dyno tune by Shiv. Zero issues...just loving the car.
Old Nov 1, 2006 | 04:05 PM
  #43
joshesh's Avatar
So does v380 (stage 0) get you around 257 whp?
or does it actually make 270 whp like the dyno graph from Vishnu says?
How did Vishnu get 270 whp on thier dyno run with the same flash that yldMr2006 has (only 257 here)?
