About to have a compression test??
Old Oct 29, 2006 | 06:15 PM
jrsimon27's Avatar
hi freinds tomorrow i will have a compression test on my evo!
question:
i have a stage1 so my cam gears are set at -5,-5 will this affect my readings of my compression test, do i move the camgears to 0,0 or i will be fine and i go ahead and do it?????????????
thanks!
Old Oct 29, 2006 | 06:56 PM
hopper's Avatar
that wont affect your compression test ur ok
Old Oct 30, 2006 | 04:05 AM
jrsimon27's Avatar
^^^thanks
Old Oct 30, 2006 | 08:49 AM
Cajun Power's Avatar
+1 no effect on compression test.
Old Oct 30, 2006 | 10:01 AM
jrsimon27's Avatar
well i did the compression test and this are the results:
1cy---162psi
2cy---162psi
3cy---162psi
4cy---164psi
i think its great cause ive been roadracing,streetracing and track racing my car since it passed the 1250miles then i modded my car at 5500miles and my car has 14700miles.
i did this test cause i always drive like a madman always reving to redline and pushing my car to its limit.
but i do the proper maintenance at time, i always change my engine oil every 3000miles
check plugs and all filters..
Old Oct 30, 2006 | 10:05 AM
shiv@vishnu's Avatar
Looks great
Old Oct 30, 2006 | 10:30 AM
jrsimon27's Avatar
^^^^^ the results make me feel confident regarding vishnu and the vishnu products are clearly reliable and trustworhty
thanks!!!!!!
Old Oct 30, 2006 | 11:29 AM
Vishnu_Evo8's Avatar
your running a base map too right?
Old Oct 30, 2006 | 12:15 PM
jrsimon27's Avatar
yep its the off the shelf base map from the vishnu site^^^^^^^^
Old Oct 30, 2006 | 12:44 PM
I have about the same readings. I drive like you too.
But, I have 58,000 miles. My car has had cams, cam gears and more since 3,000 miles. Always with an Xede and a Shiv tune. I just got my 4th Shiv tune last month.
Old Oct 30, 2006 | 12:53 PM
jrsimon27's Avatar
good to know,so my engine will last a long time!
