Baseline Dyno At Full Function ( check it out )
Old Nov 16, 2006 | 08:06 PM
MyLuckyIX's Avatar
Car = Evo Ix Mr
Mods = Garage Hrs CatBack / Perrin Tp / HKS 2.75in Downpipe / Works High Flow Filter / GFB Bov / XFlash /
on 91 octane ( 76 gasoline )
Hello everyone name is Chris, just got back from Full Function for a baseline dyno and i don't know how to feel right now, maybe cause the dyno reads so low but it has made up my mind to buy a turbo kit lol. Now I realatively have the same mods as this other car in Shivs last thread ( 305whp on mustang dyno: Stage 1 EVO IX Baseline does good ) exept being my downpipe is 2.75 n his being 3in and i have a Works drop in. Looking over the two charts mines and his, he has 20 more whp as i dyno'ed at 285whp and 278tq and his car dyno'ed at 305whp. But then again I have more AVG. whp by 12whp and more Min. whp. But the high end 300whp i wanted to break into just didn't happen. But at least Sean from Full Fuction said my AFR is just outstanding I thank Shiv for that, well all in all it was a good day I baselined jus to see were i'm at hopfully i can pick up a turbo kit soon or maybe that 20g-Lt hahaha so many things soo little money lol well see
Heres My Dyno In The Attachment
Attached Thumbnails Baseline Dyno At Full Function ( check it out )-full-function-dyno-.jpg
Old Nov 16, 2006 | 08:58 PM
joshesh's Avatar
why didnt you just buy a stage 1 upgrade from Vishnu in the first place if you wanted to see 300+whp?
I was thinking of buying a different exhaust and have then custom tune but I might run into what you are, lower whp with supposedly better components.
Now I just want to wait until I can get the stage 1 on my IX and not really mess with anything else except a works drop in and maybe new intercooler pipes. I just want to see the numbers above 300 whp and I might even use the test pipe full time if it is not too loud for me to handle.
Old Nov 16, 2006 | 09:13 PM
meanmud's Avatar
I have a test pipe - it ain't as loud as some TBE's around here
Old Nov 16, 2006 | 10:07 PM
mmoranda's Avatar
Take the Works shizzle out of your car, Dynos hate that ****.
Old Nov 16, 2006 | 11:20 PM
Erik@MIL.SPEC's Avatar
Stop being stupid.
Old Nov 17, 2006 | 02:43 AM
Vishnu_Evo8's Avatar
the dp amd cat may be killign your top end hp.
Old Nov 17, 2006 | 06:56 AM
Dabaysevo's Avatar
Yeah HKS downpipe is not 2.75, it's barely over 2.5, I had one on my VIII. The downpipe is overpriced for what it is. If I was going 2.75 over 3" I would consider the Tanabe blue TBE since it is a complete solution. You might be running into problems because of your small downpipe running into the large dia. HRS catback. I don't know anything about the filter but I don't think it would reduce your numbers. I don't think you need a larger turbo to get big numbers out of a IX, rework your part selection and retune, When I hit 322whp at Full Function on race gas my VIII pulled like a plane taking off in 5th gear.
If I could hit those numbers on a IX with the stock turbo on pump 91oct, it would be the perfect driving experience since you wouldn't have a lot of lag on the stock turbo and huge amounts of torque on tap as soon as you stomp the pedal.
Old Nov 17, 2006 | 07:20 AM
3000ways's Avatar
The downpipe is probably causing you to lose some HP, but honestly your numbers aren't to far off. You dynoed on a Mustang, and while there are a large minority of Mustangs that seem to dyno like Dyno Jets these days, there still are a lot of Mustangs that dyno low. Full Functions seem to be a lower reading one. 285whp is probably well over 300whp on a Dyno Jet. Also comparing your car to the other IX shouldn't ruin your day, your car may just not be a sstrong as his, sorry these things happend. My car made 309whp and some IXs with the same mods on the same dyno, with the same tuner made 320whp+, just a reality, some cars are stronger than others.
Old Nov 17, 2006 | 07:30 AM
ROGERV's Avatar
I really don't thimk the downpipe is going to make any diffrence. Iam running the same dp and Iam at 300whp on a low reading mustang dyno, hitting 315whp on a high reading mustang dyno.
Old Nov 17, 2006 | 07:46 AM
meanmud's Avatar
Yeah - I agree that the HKS DP isn't responsible for your concerns I think back to a buddy's car that always made more power (hp & tq) than other similar VIII's and he had the 2.6" HKS DP.
It's probably what 3000ways was describing -
Old Nov 17, 2006 | 10:39 AM
MyLuckyIX's Avatar
Actually I figured out what happened last night last time Shiv flashed me for the Stage One v400 he had mention'ed that my boost guage needle was sitting a lil low about 1 - 1.5 psi under 0, so Shiv told me he had lowered the boost just to make sure it's not over boosting because on my original Xflash completely stock I made 275whp and 280tq but that was hitting 24psi on my dyno graph, now the car is hitting 1.5 bars, from what I tried to research here on the forum last night, people are saying thats about 22psi so if thats the case i'm 2 psi of boost lower than my original Xflash tune which is most likey is the biggest factory to why i'm not hitting the same numbers just a thought but i hope thats the case daymn factory boost guage lol. Well i'll sort things out with Shiv and see what I should do. Thanks for the clean replies guys.
Old Nov 17, 2006 | 10:47 AM
bluebyu36's Avatar
i have the same downpipe on my car it smaller so it actually has better spool up time then the three inch i have friends cars with over 475 to da wheel with that downpipe it defintly not that.
