Tales From the Dyno: E85 Ethanol is good
Old Nov 26, 2006 | 01:42 PM
MalibuJack's Avatar
Originally Posted by shiv@vishnu
Hiya--- When tuned for max power, we should be seeing power numbers greater than what we would see on race gas. Not only do we get the octane with e85, we also get a huge VE bump from its charge cooling effects. It's like tuning with meth injection-- only a whole lot better in terms of consistency and cylinder-to-cylinder distribution.
-shiv
You guys know I've been jonesing for E85 for years.. I am going to do some research about availability in the northeast considering the weather changes
Old Nov 26, 2006 | 01:57 PM
SuPeRNeT's Avatar
Sweet Got in my area! It looks like a lot on acorn gas stations have it!! 3.00 a gallon? I can roll like D.B. set on kill all the time!
Old Nov 26, 2006 | 02:26 PM
EvoTio's Avatar
I would definitely consider running E85 on my Evo VIII.
Shiv, would the choice in camshaft selection change to enhance the preformance capabilities of E85?
Old Nov 26, 2006 | 03:08 PM
KOEvo's Avatar
Shiv, i am wondering if you guys changed anything else on the car, like had to use a custom fuel cell or anything. I thoght there was talk of E85 being corrosive...
I wondering what your findings were in regards to this...
Old Nov 26, 2006 | 03:10 PM
shiv@vishnu's Avatar
Nope. Think of e85 behaving just like (or a bit better) 100oct race gas. With the only exception that more fuel is needed to support the same power output. So the only hardware consideration has to do with the fuel system. Things like turbos, cams, exhaust etc,. should still be addressed in the same manner.
shiv
Old Nov 26, 2006 | 04:20 PM
GT35MR's Avatar
I found out that they have E85 available in my area for only $2.11 a gallon. I was talking to the owner and he told me that it is corrosive. He said it is very corrosive for aluminum and running it on a regular basis can ruin your fuel lines or potentially your engine. But hell I'll run it on the weekends for the track, it cost less then 89 octane gas lol.
Do I need a flash and pump to run it? Or can I just go to the pump and use it? I have a evo 8 BTW
Old Nov 26, 2006 | 04:36 PM
donour's Avatar
For those of you unfamiliar with E85.
https://www.evolutionm.net/forums/sh...&highlight=E85
d
Old Nov 26, 2006 | 04:42 PM
meanmud's Avatar
Interested in NE or Mid-Atlantic availability - let us know what you find
Old Nov 26, 2006 | 04:47 PM
BiFfMaN's Avatar
as long as its anodized aluminum your ok.
here is a short list of whats fine with ethanol
Hard anodized aluminum
Teflon lined hose
Stainless steel
nickle plated brass
anodized aluminum
Fuel safe nylons and plastics
Fuel rated rubber hoses
bronze
common mild steel
non-metallic thermoset reinforced fiberglass
thermoplastic piping
thermoset reinforced fiberglass tanks as listed by Underwriters Laboratories
Buna-N
Neoprene rubber
Polypropylene
nitrile
Viton (tm)
Teflon
Old Nov 26, 2006 | 06:23 PM
tuffguy's Avatar
Dyno results (straight 91oct vs. straight E85):
Did you use the same map for both runs, or did you use a 91 specific map and an e85 specific map?
And it even smells nice too. Unfortunately, gas mileage kind of sucks
Old Nov 26, 2006 | 06:48 PM
donour's Avatar
That's certainly not going to work. First, the 680cc injectors only flow 20% more and stoichiometric for e85 is lower than that. Second, more timing will obviously be needed to take advantage of the extra octane.
d
Old Nov 26, 2006 | 07:31 PM
tuffguy's Avatar
That's what I thought. A stock IX makes 215-220whp on that dyno. How much does a turned IX make on that particular dyno? (is that the v380 dyno?)
Old Nov 26, 2006 | 07:33 PM
Jeff_Jeske's Avatar
My 2003 EVO 8 is really only a toy to me. I'd order up some injectors and start running straight E85 today If Shiv would give me the map.
Hell I've been running leaded gas for two years instead. This can't be any worse for the fuel system.
If the 30% was a confirmed standard I'd just get some 850cc injectors and run the same map I am now LOL.
Old Nov 27, 2006 | 05:35 AM
donour's Avatar
Chemically, I think E85 has 72% the energy content of non-oxygenated (sp) gasoline. So if you wanted to run them on your current map, maybe a set of 763cc injectors will work? :-p
d
Old Nov 27, 2006 | 08:01 AM
Noize's Avatar
EvoM Administrator
Shiv-
Will my AMS style 680cc injectors be enough for the Stage 2 3071 on E85, or do I need to run a little bit less boost to be safe?
E85 is in Nashville at $2.29/gallon.
Please advise us what kind of fuel economy you get on your trip. Thanks!
Seth
