Evo8 v550 vrs. Ferrari F430 video!
Old Jan 1, 2007, 09:38 AM
sparky's Avatar
Was the Evo using straight pump gas or did he have his AMS Meth kit turned on?....Do tell
sparky is offline
Old Jan 1, 2007, 09:47 AM
jrsimon27's Avatar
we had it turned off cause everytime we use it the car starts to make a hiccup kind of thing in the engine more like sputtering we still cant figure it out(this is why shiv need to come )
also he was peak boosting at 24psi and holding 22.5psi at redline,(remeber we are at 3300feet above sea level its less knock prone and the colder weather and bigger intercooler help with no knock) maybe he added and octanebooster cant remeber but his map was the 91octmap and what hepled him also i think is the different final drive ratio he has from tre!
jrsimon27 is offline
Old Jan 1, 2007, 09:52 AM
evo-mutsumiko's Avatar
awesome vid!!! evo would've beat him all day from a launch...IMO
evo-mutsumiko is offline
Old Jan 1, 2007, 10:00 AM
sparky's Avatar
Correct me if I'm wrong, but to my knowledge the mods to the Evo are:
GT3071 turbo/w Vishnu tubular header
larger injectors(size?)
Perrin FMIC
Walbro 255
HKS 280's(+1/-1)
Cusco twin metallic clutch
upgraded TC
taller final drive ratio
XEDE w/Smart
AMS Meth kit
3" TBE
cone filter.........and a bunch of other goodies
sparky is offline
Old Jan 1, 2007, 10:10 AM
jrsimon27's Avatar
Perrin FMIC
Walbro 255
HKS 280's(+1/-1)
upgraded TC
XEDE w/Smart
AMS Meth kit
3" TBE
yep the other goodies are lightweight engine pulleys and lighter rims and he removed the front and back defense from the bumpers the injectors are the ones that come in the v550kit from vishnu also his ecu has been reprogramed by them,
the only 2 things that still dont convince me are the open air filter in my opnion it sucks hot air from the engine bay and maybe thats not good and the alchy kit(this alcky kit everytime we use it the car sputters horrbible we have done a lot of datalogging and we have leaned out the fuel mixture and we just dont get it this time we wanted a clean race so we lowered boost and turned off the alcky but next time we will use vp109 and hopefully you will be back so i can give you a call btw happy new year )
Old Jan 1, 2007, 10:15 AM
jrsimon27's Avatar
next time with vp109 we will make it spike to 27psi and hold to redline 25psi and we wil be using the 100oct map with vp109 and there will be a very big difference in my opinion!
Old Jan 1, 2007, 11:10 AM
purevibez's Avatar
yup, no doubt
purevibez is offline
Old Jan 1, 2007, 01:14 PM
bluebyu36's Avatar
how much h.p did that evo have???????
bluebyu36 is offline
Old Jan 1, 2007, 01:25 PM
jrsimon27's Avatar
we dont have an awd dyno here but we hooked up the blitz profesional gauge which goes connected to the ecu of the car and it reads 502hp at the crank with 91oct! you must input weight and other stuff to it and it gives crank horsepower
afrs where 11.5 at peak boost and by redline 10.8 which is very conservative and it doesnt have any knock!
Old Jan 2, 2007, 08:52 AM
streetturbo's Avatar
Cool, with vp 109 you will toast him.
streetturbo is offline
Old Jan 2, 2007, 09:00 AM
Yme
Yme's Avatar
+1. no doubt about it
Yme is offline
Old Jan 2, 2007, 09:51 AM
dayf's Avatar
How fast were they going at the end?
dayf is offline
Old Jan 2, 2007, 10:30 AM
jrsimon27's Avatar
cant say cause mods will delete it, but the ferrari shifted to 6th gear and the evo was on 5th gear at 7100rpms!
Old Jan 2, 2007, 10:57 AM
scorke's Avatar
If your on stock sized tires I'd say thats something like 170 ish? That is, on the moon, upside down, on closed roads
Scorke
scorke is offline
Old Jan 2, 2007, 11:13 AM
bvdawg13's Avatar
lets see that race again with some race gas in the evo!
bvdawg13 is offline
Quick Reply: Evo8 v550 vrs. Ferrari F430 video!
