Getting Started with the XEDE: READ ME
Old Feb 23, 2005 | 06:15 PM
  #31
donour's Avatar
Originally Posted by shiv@vishnu
Another option would be to replace the factory vacuum line (the one with the pill in it) with a regular vacuum line (without a pill, of course) and then swap back and forth as needed.
Really the best option, IMHO, if you want to run stock or street prepared in autocross as well. If you're anything like me, you _will_ lose the restrictor pill. I lost mine literally 15 minutes after i'd taken it out.
d
Old Feb 24, 2005 | 08:12 AM
  #32
Ludikraut's Avatar
This thread should be a sticky, IMO.
l8r)
Old Feb 24, 2005 | 08:15 AM
  #33
JTB's Avatar
JTB
d
I just taped mine to the back of my glove box.
Easy to find if I ever need to put it back in.
Old Mar 17, 2005 | 12:25 PM
  #34
SuperHatch's Avatar
Does anyone know what voltage LED to use? I'm assuming 12V but I want to be sure....
Old May 27, 2005 | 10:55 AM
  #35
KillaSweep's Avatar
yeah that is a good question...i;m about to do this mod and don;t have LEDs sitting around and would need to go out and buy a couple
Old May 27, 2005 | 11:16 AM
  #36
asasin79's Avatar
this is the one i use. it is clear instead of red. it is solid green when the xede light is green and flashes red when the xede light is red. hope this helps.
Old Apr 18, 2006 | 10:30 AM
  #37
EvilBlueEvo8's Avatar
not to raise the dead, BUT....... anyone know where to get an led for this xede mod. radioshack apparently doesn't carry 2 way leds anymore.
Old Apr 19, 2006 | 12:41 PM
  #38
Agent-Smith's Avatar
That is where I got mine from, only a month or so ago.
Old Apr 19, 2006 | 01:25 PM
  #39
SuperHatch's Avatar
http://www.radioshack.com/product/in...entPage=family
When all else fails, order online...
Old Apr 19, 2006 | 02:50 PM
  #40
Originally Posted by SuperHatch
awesome. thanks. i'll take those numbers back to the store. hopefully they can understand what i'm talking about now.
Old Apr 24, 2006 | 01:12 PM
  #41
JrCRXHF's Avatar
I would like to use this system to run E-85 and then pump gas in my EVO 9 in the next year. I have a still that we are going to make our own ethanol in. I have ran a few tanks of E-85 in my Honda CRX with a turbo B16 and it worked great the major problem was to small of a gas tank and availability but i really think it would be nice to use my own fuel in the EVO too. Do you think this ecu with the 2 maps would do the trick with a new fuel pump and bigger injectors?
