MAP referenced XEDE
Old Oct 22, 2003 | 10:22 AM
ez76's Avatar
MAP referenced XEDE
Anyone done this? Is this the key to tuning with a better breathing intake?
Old Oct 22, 2003 | 11:00 AM
shiv@vishnu's Avatar
Re: MAP referenced XEDE
With the flow rates that the factory turbo is capable of supporting, there is virtually no restriction with the factory airbox. So upgrading to another intake, few of which are cold air ducted, should yield no improvement. I've run off of MAP on our shop car and have yet to see a discerable improvement over the standard MAF deal. About the only thing we could do extra with MAP basing the system was to vent the BOV to atmos and not cause stumbles/misfires. But once again, I see no improvement with upgrading the BOV. In fact, the forge unit (recirculating) I stuck into our shop car causes compressor surge with every spring combo I've tried it with.
Just my 2c,
Shiv
Old Oct 22, 2003 | 11:11 AM
ez76's Avatar
Good to know!
Old Oct 22, 2003 | 01:06 PM
Obsoleteasian's Avatar
i see no reason to change the stock airbox, but although since the idea is mentioned, what would the possiblilities of developing a map that would cooperate with a VTA BOV such as the HKS SSQV. Its not really a big deal for me, but its an idea I would like to see discussed. Personally I finally got to install the XEDE on my new stock evo, after having it sit in my house for a good 1 1/2 months. My last evolution didn't make it due to crazed minivan zombie. So far I have the SubZero installed and find its improvement great over stock. It makes the car feel complete as a whole. So far no issues of any kind, *knock on wood*.
Old Oct 22, 2003 | 01:09 PM
Eric Lyublinsky's Avatar
I just loaded that map and did some boost mapping and now it's complete! Just smooth out the curve a little. world of diffrence.
Enjoy
Eric
Old Oct 22, 2003 | 01:50 PM
One thing I enjoy is that the custom mapping program is free, so I can edit the maps which further more justifys my purchase, although not a huge issue but I would like to see this program cleaned a little bit and probably pushed out of Beta2 into a final version.
Old Oct 23, 2003 | 03:26 AM
limey's Avatar
Re: Re: MAP referenced XEDE
Just my 2c,
Shiv
I am glad you found this with the Forge...I thought I was missing something..I have also tried every possible adjustment variable with this recirculating valve...now it is being used to stop my papers blowing away on my desk...
Old Oct 23, 2003 | 03:31 AM
doc_evo's Avatar
Shiv or anyone,
So what BOV do you recommend? Also, will changing BOVs after a tuning session affect the tune? I'm also running the Forge recirc; will this hurt anything? Thanks.
Old Oct 23, 2003 | 05:23 AM
EVOlunchbox's Avatar
I have a Forge also, and I am having some problems with it as well. I have huge flutter/surge no matter what I do to the darn thing. I have it installed backwards, and it seem to be working better... some on something needs to be fixed here. Thinking about going back to stock, unless there is a perfect solution. I also want to send it back and get a refund. Not sure if thats going to happen.
Old Oct 23, 2003 | 09:01 AM
MP5's Avatar
MP5
In Timeout
What man the XEDE interface rocks- I guess I you havent played with the UTEC bro. Anyway with the question of the xede working on aftermarket VTA BOV- Why?? this ist a performance mod - Maybe the Xede pro will have the power to do it but I personally see no reason for Shiv to wast his go fast R&D time to waste on bling bling mods or to correct for mispurchaces of expensive intakes and BOVs when the factory is quite up to the task. Also compressor surge is no good thing!! I have always liked shivs less is more approach get that crap off your car and sell it to someone else who THINKS they need it.
Old Oct 23, 2003 | 09:24 AM
haha ya, you got me. . i was just curious to discuss about it. i know no true gains are seen from it. only reason i was wacked out on the design of the interface is because i am new the custom map programs, and my interactive design side came out when i opened it on 800x600 resolution. ill keep my game where it belongs, defintely not in car programs :-p
Old Oct 23, 2003 | 09:37 AM
MP5's Avatar
MP5
In Timeout
No man dont take it as a slam it wasnt. Im sure Shiv welcomes all XEDE users thoughs but the interface is miles better than Ive seen except for all out stand alones- I see am just peeved a little when guys spent $300 on a bov (that could potentially cause turbo damage) and a $200 under hood intake that induces error into a properly reading and calibrated MAF and then in the same breath try to tune out the 2 "performance" mods with ECM tuning.
It doesnt make sense to me. I guess if the tuner takes this into account with there own pre programed ECM points it really isnt worth mentioning as its probably fine.
Old Oct 23, 2003 | 09:43 AM
ya i gotcha... no worries i didn't take it as a burn. ya i didn't like the intake on the evo when i got it, i felt cheated in some odd way, and it wasn't worth it. of course my new car i am keeping the stock system, my questions are that in the future will the stock bov be able to hold the boost or will it have to be upgraded to anothe reciculating system later... 2nd is it worth it to buy a drop in filter or is that useless and mp5 what are you running on your car.. modifications. and your name should be mp5sd5 my fav.
Old Oct 23, 2003 | 10:01 AM
MP5's Avatar
MP5
In Timeout
yes my fav too I have a Vishnu stage 1 with a 2.5" turboback (that will be replaced soon with a 3" its costing me ~ 15HP ) I havent had good luck with the reusable oil based drop ins in the past it gooked my MAf on my wrx multiple times and just wasnt worth it. I personally saw a WRX on the dyno make a pull with a K&N the owner quickly switched out to a cheap fram paper filter and instantly gained 5 HP. No crap about it it happened nothing was changed except the car getting more heat soaked from the previous pull. There was a very smart tuner sitting in the car that only smiled in an I told you so manner . We arent going to overdrive the factory DV with the stock turbo the stage 1 all but does that now- though I do have a lust for the BR upper IC pipe / with 1stG DV but its just to free up underhood space and cut down on IC piping not really for the effects of a metal vs plastic DV
Old Oct 23, 2003 | 10:05 AM
I do wish we had the same DV from the WRX. Just a great unit built like a brick **** house. Seems to be the same as the 1st Gen DMS one.
