XEDE bogging/stalling
Old Oct 27, 2003 | 02:16 PM
bigd's Avatar
Re: XEDE bogging/stalling
Originally posted by jman425
Just installed my new Xede last weekend (swapped out my old unit). Everything seems to be working fine, just the annoying tick of the relay during boost. Yesterday, while merging into freeway traffic, the motor seemed to stall for about 1/4-1/2 sec during acceleration. the ticking stopped momentarily, then continued as the motor started going again ?
Anyone experience this problem ? Any inputs, Shiv ?
Heya J!
A couple of things:
1) Make sure you have the boost controller hooked up correctly (do you have a boost guage?). If you are boosting at 100% of the boost solenoids cycle all of the time and you have taken out the restrictor, you could conceivably hit fuel cut.
2) Make sure that none of your connections can touch metal. If you have the P&P cable, make sure the PCB cannot make contact with anything metal under the dash.
Also, what map are you running? I have run the 91 oct Subzero, Stage Zero and Stage Zero + without hitting any sort of fuel cut. I did however have stalling when I had the cable in a position to make contact with metal. Once I fixed that, there were no problems.
Old Oct 27, 2003 | 02:23 PM
jman425's Avatar
Thanks D ! Where were you for our little meet yesterday ?
I'll go check on my connections later on today....
Steveevo9
Jun 1, 2009 11:03 PM
jasonrp15
Southeast Region
Feb 28, 2007 08:45 AM
sayanara
14
Jan 3, 2006 01:28 PM
