whats the problem Shiv!!!!!
If you want optimal tune, custom dyno tuning is necessary. This applies to any car, any set up, any time. The baseline maps are just that, baselines. They are designed to accommodate the lowest common denonimator which they do most of the time. Every now and then, we'll come across a car that wants to make more (especially those running test pipes like yourself) or sometimes less boost than normal. This is when user-adjustability pays off since things can easily be compensated for.
When I say that 21psi peak is good, I mean it's good and safe. Safe enough to be far away from the fuel cut and high enough to provide a nice boost in power.
Regards,
Shiv
PS. Another reason you are overboosting is that you are running a set-up which we don't have a map for. We don't have a map for a cat-less Stage 0 plus DP on the website. But I just made one and emailed it off to Andy at Extreme. It should take care of the overboost issue. If not, Andy has my number and will call me.
Regards,
Shiv
Originally posted by evo8power
so yes it is working to "OPTIMAL' performance or "that shoudl be fine"......that worries me when i spent 900 bucks and waited a month, not to be rude but i want honest, and acurate sugestions.this is my daily driver and i weant it fast but also to last....thanks.....
thanks shiv, im not trying to be a d*** im just a little frustrated because i want my car running right..you think i should put back on high flow cat and stock BOV??? when are you gonna be near Philly or the east coast so i can do a custom tune....thats what i wanna do!!!! so please let me know and woudl i lose power with stock BOV and cat?
thanks
thanks
A bov is DUMB, put the stock one back on. also the cat being off should be okay, I just don't like the smell for 5HP and a CEL.
thanks
thanks
thanks
thanks
If you install an aftermarket BOV that allows the discharged air to go back into the pre-turbo intake-tract, there is nothing dumb about it.
If you install one that does not discharge back into the pre-turbo intake-tract, then you will likely have issues at part throttle with unmeteed air getting in or metered air getting out.
How do you know it leaks? See there is always a lot of talk but no facts to back this up. Tell me why and how you know it leaks?
Originally posted by ShapeGSX
The stock BOV leaks. That means that the turbo spins faster than it should to produce the boost you see in the intake manifold. This means that the air in the intake manifold is hotter than it needs to be.
With our Stage 2 car mapped to run at 25psi, replacing the stock BOV with an recirculating aftermarket unit picked up another 2psi of boost and 20whp. At 21psi of boost, however, the difference between the stock aftermarket BOV was insignificant. We tested 3 stock BOVs and found them all to leak just above 21-22psi of boost. So as long as you run under 21-22psi of boost, there is no measurable gain with running an aftermarket BOV. The only thing I picked up with my Stage 1+ car is partial throttle compressor surge and other misc. drivability issues. There is a way to modify your factory BOV to keep from bleeding at higher pressures. We're testing it right now.
Cheers,
shiv
Cheers,
shiv
Cheers,
shiv
Cheers,
shiv
Would like a ture direct replacment one that works and does not flutter. You think somthing like that is going to happen from the house of Vishnu??
BosanskaTrava
20
Apr 1, 2008 09:19 AM
SuperHatch
231
Feb 14, 2005 03:50 AM
