Loading a new xede map
Old Jan 7, 2004 | 02:05 PM
shiv@vishnu's Avatar
Originally posted by Ryanmcd3
Quick one, when I 0 out the boost maps they still stay at 50 something they never goto zero. Is that right?
nope...it should go to zero. you are using xmap v.2 (beta), right?
Shiv
Old Jan 7, 2004 | 09:38 PM
BMo's Avatar
BMo
ez - thanks for the insight!
ryan - no! those clips attaching the plastic air intake piece to the frame broke when i took everything apart to remove the little brass restrictor pill in the boost line. you think that's the culprit of my "squelch" sound (which sounds like water being sprayed at high velocity)? I guess it's worth a try and easy to remedy!
Thanks
Old Jan 7, 2004 | 09:48 PM
sr20det91's Avatar
Those clips have caused many problems. Mainly the snorkle closing itself off against the hood at higher RPM. I would not do anymore tuning untile you have the snorkle secured. Fix it and start over. I'm almost positive thats whats causing you squelch sound.
Old Jan 10, 2004 | 05:34 PM
BMo's Avatar
BMo
quick update - I secured air intake piece to frame and boost problem at redline has not returned, ergo problem solved! You guys rock! My evo's running better & better all the time!!!!
Old Jan 10, 2004 | 10:36 PM
Ryanmcd3's Avatar
In Timeout
Yes, Ken is sending me a new harness on Monday. Thanks again for the great support!
Shiv
Old Jan 10, 2004 | 10:37 PM
Ryanmcd3's Avatar
In Timeout
Ya, that problem kicked my *** for a few weeks. Now it's zipped tied down WITH the clips.
