Dyno Results: Stage 1+ 100oct
Old Jan 8, 2004 | 09:54 AM
Ryanmcd3's Avatar
In Timeout
hehe I can see it, maybe because I look at stock charts all day and it looks like a dbl top to me
Originally posted by MP5
I think it looks smooth
Old Jan 8, 2004 | 10:12 AM
shiv@vishnu's Avatar
Originally posted by Ryanmcd3
So that's about 350whp on most other awd dyno's? I thought you were making that on your last trip?
Stage Ones with cams put down 340-345whp
Also any dyno charts?
In CO, due to the super high altitude, SAE correction factor was a big fat ~1.2 which means that the cars which put down an SAE corrected 345, really made 345/1.2 at the wheels. The SAE correction is simply to estimate what power the car *should* theoretically put down at sea level under standard conditions. It's nothing more than an estimate and questionable at best. The 300 the car is putting down on our DD dyno is actual and essentialy uncorrected (CF of .99) which puts it close to 400 crank hp by most reasonable estimates. Maybe 10 or so more hp if we were to replace the at with a test pipe.
Got some more Stage 1 cars to do today and tomorrow. Should have more updated Stage 1+ baseline which I'll then circulate.
Cheers,
shiv
Old Jan 8, 2004 | 10:16 AM
Ryanmcd3's Avatar
In Timeout
Sounds good man, Also this car is super smooth with the stage 1+.
Cheers,
shiv
Old Jan 8, 2004 | 10:40 AM
jsotican's Avatar
Shiv:
What was the cam setting?
In CO you ended up at -2 degrees I believe. Since Diane's EVO was one of the early ones you dyno'd in CO we are still at -3 degrees. I'd like to make that small adjustment if you recommend it.
You're the BEST!!!
JS
By the way, could you recommend a high-flow cat?
Old Jan 8, 2004 | 10:43 AM
MP5's Avatar
MP5
In Timeout
Originally posted by jsotican
Shiv:
Vishnu TB has a HF Cat
Old Jan 9, 2004 | 12:35 PM
ez76's Avatar
I LOVE THIS CAR. Near full boost at 3300rpm and 3000rpm of meat in the torque curve means this is a DWIW (do what I want) machine.
Old Jan 9, 2004 | 12:43 PM
MP5's Avatar
MP5
In Timeout
Mines nice as hell right now I can only imagine yours!! Whats your gears set at?
Old Jan 9, 2004 | 12:53 PM
ez76's Avatar
-2/-2 (advanced from -5/-5 with stage 1)
Old Jan 9, 2004 | 01:35 PM
BadBoyBeltran's Avatar
I guess I need to get cam gears, or should I just have it at -2/-2 when I install the cams?
Now I'm debating whether to get the X-Flash or go with the XEDE and XEDE- Flash. After stage one, I'll probably stick w that set-up until I graduate (Summer or Fall 2004). Then its sky is the limit from there
What do you guys think?
STi
Old Jan 9, 2004 | 03:54 PM
Aby@MIL.SPEC's Avatar
When I get a stage 1+, how much HP or drivability will I be leaving on the table by only running the xflash vs the xflash/xede combo on 91 octane?
Old Jan 9, 2004 | 04:00 PM
MP5's Avatar
MP5
In Timeout
Shiv says he can tune them pretty close. The only real disadvantage (and he mighta figured it out already) is the knock attenuation
Old Jan 9, 2004 | 04:11 PM
Thanks, I am really looking forward to the knock feature along with the 02 reading ability of the xede.
Those are 2 features too tough to live without.
I am sure a self learning timap ability is soon to come down the pike to produce a perfect timap for a best power traf produced by shiv. I am also thinking about how valuable this will be for partial throttle driving as well as WOT
Old Feb 3, 2004 | 12:04 AM
Smogrunner's Avatar
EZ,
My 264/272 cams are being installed next Thursday down here at RRE. I am currently running the stage 1 xedeflash. Is my flash the same as a stage 1+ flash? I really want to steal your 91 and 100 maps from you and have them in my xede when I drop it off next Wed. They are going to also adjust my cam gears from -5 to -2.
I'm really excited and want everything worked out in advance. I also got the Walboro fuel pump which I'll install myself when it arrives.
Here's the big questions: 1. Will you email them to me (smogrunner at comcast dot net) and 2. Is there anything about your maps that make them incompatible my evo. (firmware update for example)
Hope to hear from you soon,
Smogrunner
Old Mar 18, 2004 | 08:31 PM
boomersan's Avatar
For stage 1+, I've read that it's recommended to upgrade the fuel pump... any recommendation for injectors?
Old Mar 18, 2004 | 08:39 PM
TDC's Avatar
TDC
In Timeout
No no need
shiv@vishnu
76
Apr 21, 2008 08:38 PM
