Vishnu Cam Gear Install....Any advice?
Old Jan 9, 2004 | 09:46 AM
HiVoltEVO8's Avatar
Post Vishnu Cam Gear Install....Any advice?
All of you guys that have installed them,
How difficult is the installation? How long did it take you?
I have purchased the special tool, which looks like it is inserted underneath the car from the online manual. Is this right?
I guess that I would like to get some advice before I start. Any help would be greatly appreciated.
Thanks in advance
HiVolt
Old Jan 9, 2004 | 09:48 AM
evoego's Avatar
Registered User
for the cam gears no problem, like 30 to 45 minutes, cams another story, probably 3 hrs. the tool makes the cam install alot easier.
Old Jan 9, 2004 | 09:49 AM
MP5's Avatar
MP5
In Timeout
http://www.evomoto.com/tech_info.php?techID=18
Just refer to the gear section here
Old Jan 9, 2004 | 12:57 PM
SAEVO's Avatar
awesome wright up on cam install, should help when i grow the ***** to buy my cams!!!!
Old Jan 9, 2004 | 01:38 PM
BadBoyBeltran's Avatar
Hey SA EVO,
If you can get enough people in SA to do cams, I'll be more than happy to do them for you for a very reasonable amount.
I'm doing mine this weekend. From there, I'll PM you if you and others are interested.
Old Jan 9, 2004 | 01:47 PM
SAEVO's Avatar
i know atleast one more person and i think there are 2 more in the area. i will check
Old Jan 9, 2004 | 01:51 PM
ill probably get it down this weekend if they come in today. then ill help u guys out.
Old Jan 9, 2004 | 06:07 PM
puckadog's Avatar
follow the directions on evomoto - should take 3 hrs. tool goes in from the engine compartment, little rubber plug with a tab on it to pull it out, just below the cam gear cover on the lower plastic cover facing the radiator.
Old Jan 13, 2004 | 08:56 PM
Did the HKS cams install today.
HiVolt. I personally had to take out the cams to take off the bolt that holds the cam gears to the cams. Taking these bolts out was the hardest part of the install for me. I hope you are stronger than me or have some better tools or something. I had a breaker bar and a 1 1/16 wrench to hold the cams. The stupid bolt did not even budge and I was practially ON the dang thing at one point. If you are going to change the cams, change them with the gears!!!
The difference between changing the cams and the cam gears is pretty much taking off the caps for the cams - I more step, thats it!
I also made a customzed tool for the tensioner (a threaded bold 8mm x 1.25).
STi
Old Jan 13, 2004 | 09:05 PM
MP5's Avatar
MP5
In Timeout
STi
Awesome info can you point me to it or post a pic?
Old Jan 13, 2004 | 09:24 PM
I bought a 3 foot 8 x 1.25 threaded bolt from a local store. Cut about 9 inches (what I needed) and torqued two screws on it to turn it. I'll post a pic tomorrow.
The manual syas hand tighten it. The evomoto says tighten it with a ratchet. I used a ratchet, but you can also do it by hand.
Old Jan 13, 2004 | 09:26 PM
MP5's Avatar
MP5
In Timeout
I bought a 3 foot 8 x 1.25 threaded bolt from a local store. I'll post a pic tomorrow.
Three foot? jeeze did you stand on a stepladder to twist it? What was the store? Can you ship one to me? And did it work well?
Old Jan 13, 2004 | 09:37 PM
Heres one.
Old Jan 13, 2004 | 09:38 PM
No cam gears.
Old Jan 13, 2004 | 09:40 PM
I cut a 9 inch portion. It showed a little flexing, but it was enough. I am not sure though how it would work if you are just changing the gears.
I'll confirm tomorrow. I'll fiddle with it and see how good the tensioner moves.
