Firmware news
Old Jan 16, 2004 | 09:58 AM
shiv@vishnu's Avatar
Firmware news
Here's what the newest version of XMap (currently be tested) will offer:
User definable RPM switch, above which the XEDE starts modifying the signals. Below which is completey pass-thru (for smoother idle, happier OBD-II diagnostics, etc,.)
User definable wastegate solenoid operating frequency so that it can be used with other drivers of user's choice.
Currently working on a user definable MAF switch, above which the XEDE starts to modify the signal. It's a bit harder to do than the RPM switch since it's tough to make the swithover invisible. But we're working on it...
If this works, we can keep the current MAF scaling and not have to redo all the baseline maps
Cheers,
shiv
Old Jan 17, 2004 | 07:48 AM
mhgsx's Avatar
Hurray!! I knew this would be the easiest way to get around the cold idle instability.
Old Jan 17, 2004 | 12:50 PM
Yep, but it's hard to do. There can't be a break in the MAF waveform or the car will hiccup. We're working on it now and things are looking okay...
shiv
Old Feb 17, 2004 | 10:44 AM
freedom's Avatar
Old Feb 17, 2004 | 12:52 PM
The new firmware is essentially done. However, we ran into a glitch on Friday when we tried to update the new firmware into an older XEDE hardware version. This should be fixed this week and we will advise users on what steps can be taken next. The XEDE can get its firmware upgraded by the user if they are so inclined. I'm currently writing a little instruction set on how to do this.
The MAF-depedant bypass works perfectly, BTW. In fact you have a choise to make the MAF bypass triggered by RPM, MAF, TPS or MAP.
Hopefully, traction control will also be squared away this week as well.
Regards,
shiv
Old Feb 24, 2004 | 12:04 PM
EV0lut10n_8's Avatar
Sounds good...let us know when we can get the new firmware..
Old Feb 24, 2004 | 02:14 PM
Noize's Avatar
EvoM Administrator
Holy NOT worksafe avatar, Batman! I need to turn my avatars off for the office.
Old Feb 24, 2004 | 07:24 PM
tom@kartboy's Avatar
actually its even easier.. move to Sunny San Diego
sorry had to
cant wait for the new firmware
Tom
Old Feb 25, 2004 | 08:40 AM
yeah she is mesmorizing
Old Mar 2, 2004 | 11:18 PM
Lacoste's Avatar
Question Firmware update coming?
So, what's the status? When can we download this? PM me if you want someone to test your instructions for you.
Lacoste
Regards,
shiv
Old Mar 3, 2004 | 04:39 AM
meanmud's Avatar
bump!
Old Mar 7, 2004 | 04:19 AM
Lacoste's Avatar
bump
Old Mar 10, 2004 | 12:09 PM
Lacoste's Avatar
b-bump
Old Mar 11, 2004 | 09:30 AM
any word on this?
Old Mar 15, 2004 | 10:18 AM
Lacoste's Avatar
Arrow New XMap for new fw
Well, according to Shiv there is a newer version of XMap designed to work with the newer firmware: there are new features that "will not be operational until the XEDE is updated with the appropriate firmware"
Hopefully we will see something about getting the new firmware this week.
Lac
