cam gears
Originally posted by shiv@vishnu
Sounds right to me.
Shiv
Sounds right to me.
Shiv
ok after not being able to get rid of the CEL p0141 i got to examining these numbers and the whole time it was wrong. so i am now running 11degrees advanced since the zero degree on mine should be at 7degrees retarded. help help help does this sound ritght now???
ok can you help me on dyno day cause i'm hella confused and havn't driven my car since i got cel last weekend. hopefully my cel will go away after the timing is set properly.
i won't drive till then and its like 45 miles to there from mi casa. i did drive from there last saturday and got a cel. i will bring an extra o2 sensor just incase mine has been en-riched and is clogged.
yes i am at +4 but i am 7 degrees advanced since they were installed with the 0@tdc so i am really at +11 so i could move to -10 and they will be at -3...this **** is too confusing/annoying. time for mark & coke.
Originally posted by Smogrunner
Wait, MP5, do you agree with me that asasin is set at +4 according to his photoshop marks?
To asasin79: !!!Warning!!! *******The red dot is to align the gears TDC, the degree marks are for the settings. if that green line is where you've set TDC, you're lucky the motor didn't let go the first time you fired it up. You must use the red dot to set to TDC. If you can't set the red dot to TDC, have the car towed to somewhere that can. DO NOT drive the car if that green line is where you set TDC.. Don't even start it anymore!*******
basically they need to be -10 from tdc no matter what is installed up. right?
cam gears, Hell even I did not screw that up lol. Hey those look like mine :-) Anyone put the RED DOT on the rib at +9 on both gears. The loosen the 5 allen bolts and set the white mark at -3 on both gears, tighten them down and use the RED dot as TDC. Also use locktight on them lol.
Originally posted by Noize
The blue line setting would be +4, but the actual gear at the time of that picture is set at -2. There is A LOT of confusion about this for some reason.
