XEDE and Knocking???
Old Apr 21, 2004 | 10:34 AM
YEVOVIII's Avatar
If I take the car to the dyno and set up the laptop to the XEDE where do I go and look to see if the car is knocking? I am just worried about my little proble when I slowly roll into in 2nd from 2000rpm to redline I still feel that little power loss at around 5600-6000 rpm. I am afraid that I am knoking bad and the XEDE is pulling timing. How can I check this with the XEDE?
Thanks
Tony
Old Apr 21, 2004 | 10:57 AM
Noize's Avatar
EvoM Administrator
If you're running a shelf map, I highly doubt you have any knock in the middle section like that. Who installed your cam gears? Are you sure you can't get a babysitter or just bring your daughter to the Georgia dyno day?
Old Apr 21, 2004 | 12:43 PM
YEVOVIII's Avatar
-5,-5
Right Noize? With stock cams the stage 1 cam gears should be set at -5,-5? When is the dyno day? I am doing everything I can to go.
Tony
Old Apr 21, 2004 | 01:34 PM
Noize's Avatar
EvoM Administrator
-5,-5 is right. Where did you set top dead center? From zero or the red dot?
Old Apr 21, 2004 | 01:52 PM
YEVOVIII's Avatar
HMM
I set TDC from the red dot. Please tell me I was right?
Old Apr 21, 2004 | 02:01 PM
Noize's Avatar
EvoM Administrator
Yeah, that's right. I can't figure out why you're getting a stumble.
Old Apr 21, 2004 | 02:12 PM
Dyno4mance's Avatar
Mine stumbles at that range slightly Seth....not a big deal, it is the xede reducing boost in the mid range that causes that in an off the shelf map
YEVOVIII the dyno day at our shop is on May 15th & 16th...hope you can get to come
Old Apr 21, 2004 | 02:49 PM
Noize's Avatar
EvoM Administrator
I wish I brought my car down there last weekend. I want you to drive it. My friend Paul wants me to come back down this weekend with him, but two in a row might be hard to squeek through the wife.
Old Apr 21, 2004 | 04:37 PM
Dyno4mance's Avatar
C'mon Seth....work it man, bring the wife ...we can send em out shopping......although I am sure Nashville shopping is better than around here...
