To be Tested
Old Apr 29, 2004 | 04:24 PM
ogvw's Avatar
Originally Posted by steve_evo
If this is the street/track setup, I believe a member on the board named OGVW has this on his car. He works for the Ohlins company and he is trying new spring rates and supposedly this will be used in the kit offered by Ohlins.
Shiv, are you working with Ohlins on this or are you using your own rates/valving?
Also are these units the PCV series from Japan or are they the units from Sweden?
Thanks,
Steve
We are working with Shiv to help develop a track setup using the MIS kits (designed in Sweden, made in Japan) I already have a SWEET dual purpose setup on my car using off the shelf Ohlins parts and changing spring rates a bit
Old Apr 29, 2004 | 04:26 PM
steve_evo's Avatar
A ha... I was right!
Old Apr 29, 2004 | 05:58 PM
jj_008's Avatar
ogvw, If you need another beta tester go ahead and PM. I will put them to the test.
Old Apr 30, 2004 | 01:00 PM
gtr's Avatar
gtr
Originally Posted by JT-KGY
I'm actually hoping to see ECU tuning (flash or piggyback) that will leave the stock boost
setting alone... but so far, I've found none.
I believe the first version of the xede does not have the boost control feature. I'm sure if you call Shiv he'll help you out.
Just go into SM. I'm sure the evo would do fine with some coilovers. The evo is slower than the ZR-1 so it's not really the best car.
Old Apr 30, 2004 | 01:09 PM
954DRGSR's Avatar
These?
http://www.ohlins.com/pdf/productnew...t_20030923.pdf
Old Apr 30, 2004 | 01:24 PM
ogvw's Avatar
Originally Posted by 954DRGSR
Yes, those but with different rates - more info here ohlins review
Old Apr 30, 2004 | 04:21 PM
JT-KGY's Avatar
Nah... SM requires R comps to be competitive... STU will be much cheaper to prepare..
Old May 2, 2004 | 12:06 PM
cokofellah's Avatar
Ohlins suspension
Shiv,
OHLINS? Nice move man....I am sure you'll dial em better than we did.
Anyway, let us know when you're ready to offer them....I'll probably be your first customer....cool
Old May 24, 2004 | 04:56 PM
KillaSweep's Avatar
I'm interested as well...currently in the market for coilovers.
Old May 27, 2004 | 04:48 PM
BJai02's Avatar
Shiv,
So how the XEDE firmware v1.8 come along in One Lap America? I am looking forward for the close loop fuel control.
Are you now using a new method for the boost control instead of taking out the pill from the line? Seems like your instruction on webpage has not been updated yet.
Old May 28, 2004 | 03:15 PM
BJai02's Avatar
Bump for Shiv!
