Found Problem With Exed
Old May 11, 2004 | 05:09 AM
EVOeight's Avatar
About every 10 key cycles or so, the Exed will only allow 12lbs of boost, no matter which map you are using. You can try switching back and forth between maps, no help. You have to actually turn off the key, wait about 5 seconds, then restart the car. Then you have 20lbs of boost again. That is a very strange problem and I have heard other people with this same problem with their Exed. I have a brand new Exed, only about 3 weeks old. Other than that problem, it is awesome...
Old May 11, 2004 | 05:40 AM
Noize's Avatar
EvoM Administrator
Mine has done this one time out of several hundred starts. Happened last week. I shut the car off on the road, restarted it, and everything was great.
Old May 11, 2004 | 05:48 AM
meanmud's Avatar
No problems here
Old May 11, 2004 | 06:44 AM
YEVOVIII's Avatar
Yep that happens to me once a week also.
Old May 11, 2004 | 06:48 AM
n00dle's Avatar
What version firmware do you guys have? To see which one you have, go to "XEDE information" and see what it says. You want to have 1.7.14
Version 1.7.12 which had that glitch during start-up where you need to key "ON" for a few seconds to let the XEDE maps load up from memory before turning the engine over has been updated to version 1.7.14 which is supposed to be 100% bug free. The older firmware that most people are running 1.6.x is also bug-free and stable.
Old May 11, 2004 | 07:17 AM
jj_008's Avatar
Mine has done that three times and I have the latest firmware.
Old May 11, 2004 | 07:28 AM
asasin79's Avatar
i have the same issue...i just keep the xede to where i can see the light if it is flashing red i kill it and restart i never drive like this. i will try to upload the new firmware.
Old May 11, 2004 | 08:44 AM
shiv@vishnu's Avatar
When low boost happens, is the light green or is it flashing red?
Shiv
Old May 11, 2004 | 08:59 AM
jj_008's Avatar
Actually, my XEDE only started doing this after I sent it in to Vishnu for the newest firmware.
Old May 11, 2004 | 10:35 AM
cjb's Avatar
cjb
I have had this happen too (.8 bar or so)... I haven't looked at the LED's to see what color they are though. The next time it happens, I'll check the colors.
I believe I'm running the latest firmware as well.
Old May 12, 2004 | 07:24 AM
EVOeight's Avatar
I did not check the light status when this happened. I will be sure to check it the next time it does this...
Old May 12, 2004 | 09:05 AM
Yes, please check. With enough info, it's pretty easy to diagnose and correct.
Cheers,
shiv
Old May 12, 2004 | 09:59 AM
ogvw's Avatar
check the ground..... mine used to do it until I did this:
Solder a good terminal to the ground wire (not crimped!)
add a second or third grounding strap to a cleaner ground source
seems to be fixed ever since
Old May 12, 2004 | 10:35 AM
FDizzleBrett's Avatar
God, he's good at everything
Brett.
Old May 12, 2004 | 08:49 PM
cokofellah's Avatar
can't get enough of this stuff
