Will cam gears pass smog?
Old Jul 22, 2004 | 12:00 PM
n00dle's Avatar
Cam timing is not the same as ignition timing, which is what will be looked during a smog inspection. Adjusting the cam timing does not inadvertently adjust ignition timing, nor does it automatically fail it. With smog checks using OBDII this simplifies what the tech needs to do. All of the data goes directly to the DMV. About the only thing the tech has to do is a visual.
Old Jul 22, 2004 | 12:01 PM
snoop's Avatar
Originally Posted by EvolutioNiK07
Well, Boostez, you made a good analogy but you faulted when u brought up the alternator into the picture as this has nothing to do with Emisssions and the Cam gears and timing has everything to do with it. If you bought an OE replacement thats fine whether its from Mitsu. itself or someone else, but if on the other hand you were to buy an aftermarket "off-road" use only cam gears with/without different setting on the timing THEN you would fail smog, functional/visual. I'm not sure about other states laws on this, so i can only confirm this for Cali. ppl.
I am moving to Socal this week and I kept all my stock parts for this reason.
How much is smog test in CALI?
When will 2003 EVO's have to take the test?
Thanks,
Snoop
Old Jul 22, 2004 | 12:19 PM
Noize's Avatar
EvoM Administrator
I highly doubt every CA test center employee whips out his handy 10mm socket to pull the four bolts out of your timing belt cover to look at your cam gears. If this is true, California blows goats.
Old Jul 22, 2004 | 01:13 PM
Darkstar1's Avatar
Thanks,
Snoop
Welcome to Southern California! New cars are exempt until their fifth year, but an out-of-state car being registered in CA will require a smog check. Here is a link to more information:
http://www.smogcheck.ca.gov/stdhome.asp
Old Jul 22, 2004 | 03:40 PM
n00dle's Avatar
Originally Posted by Darkstar1
Thanks for the link. If anyone's interested here's the list of items they test for. It does not list cam gears or cam timing as being one of them, therefore simply having them does not automatically fail the car.
http://www.smogcheck.ca.gov/ftp/pdfdocs/failvir.cap.pdf
Old Jul 22, 2004 | 05:47 PM
RonV's Avatar
Well, as a smog technician i would have to take off the cover to make sure that the timing is set at the ECS(sticker underneath the hood) recommendation. And if i see aftermarket cam gears installed, under law, i have to report that as a failed item.
As a smog technician you are not requred to take off the timing cover. Were did you get the idea that you should be removing timing covers and looking at the chains and or belts? This is not part of any smog test that is required, even in Cali. I'm calling BS.
Hell, on some cars you would have to remove the water pump,powere steering.......etc.
What a crock.
Old Jul 22, 2004 | 06:21 PM
Noize's Avatar
EvoM Administrator
Yeah, I think the guy is full of shat too.
SmurfZilla
Aug 16, 2015 03:50 PM
hiner005
12
Jun 28, 2014 11:32 AM
kpt6
Mar 21, 2014 05:12 PM
rcantu
Feb 21, 2014 07:43 PM
