PO300 Fix
Old Aug 15, 2004 | 01:59 PM
shiv@vishnu's Avatar
Talking PO300 Fix
Well, we think we found a fix. At least on the car we have been playing around with. But to confirm things, we'd like to test it on more EVOs. So if anyone local has cronic (more cronic the better) P0300 issues, PM me and we can try something out on your car. It involves a quick diagnostic and a few runs of dyno testing. All free of charge.
This "fix" is done through the XEDEFlash and XEDE so you will need to be equipped with both items. This fix does not apply to XFlash-only cars since a good portion of the "fix" in incorporated in the XEDE hardware. I'm putting "" around "fix" until we can confirm that it is indeed a fix But we're pretty hopeful...
Regards,
shiv
Old Aug 16, 2004 | 03:16 PM
BOOSTEZ's Avatar
Regards,
shiv
Well, that blows. Can you not figure out how to fix it with XFlash-only cars like the dealer or the other XFlash manufacturers?
-M
Old Aug 16, 2004 | 04:43 PM
David@Vishnu's Avatar
-M
Ugh we are the only xflash manufacturer. Mitsu didnt fix the 0300 at least on the cars that were flashed and still throwing it. Also NO OTHER tuner has fixed it
Old Aug 16, 2004 | 06:57 PM
BOOSTEZ's Avatar
Then why does DynoFlash and Buchur state that they have fixed it?
Hmm..is it a problem with the ECU or the knock sensor? Perhaps a better designed knock sensor would be better as it wouldn't be so sensitive in the first place and throw the code.
-M
Old Aug 16, 2004 | 07:10 PM
-M
The knock sensor isnt involved. Please we arent here to argue Ive seen plenty of other tuners cars with 0300s.
Old Aug 16, 2004 | 07:49 PM
-M
I dunno
Old Aug 16, 2004 | 08:13 PM
erioshi's Avatar
You have my PM. My car started throwing P0300 codes at about 22K, and hasn't stopped since. It's gotten to the point where if I run the car for more than 30 minutes it will definitely throw the code. At times the code will trip within a minute or two of starting the engine.
I even keep a code scanner in the glove box for clearing them.
Old Aug 16, 2004 | 11:52 PM
evo_engineer's Avatar
no 04 and no p0300 xflash. what should 05 owners expect?????
Old Aug 16, 2004 | 11:57 PM
FastHung's Avatar
I dunno
Is that suppose to be funny? I might have to get dynoflash because i cant get rid of p0300?? I call 2 week ago and no one pick up.
Old Aug 17, 2004 | 12:33 AM
Wizard_of_Evo's Avatar
just try calling again. i call all the time, and about 1 in 8 i get the voice mail. just give them another call. it's worth it.
Old Aug 17, 2004 | 12:51 AM
Don't bother feeding the trolls guys. They are brand new accounts with 1 post to their names
Shiv
Old Aug 17, 2004 | 01:14 AM
JohnnyChimpo's Avatar
Hey Shiv...you flashed me at XS a couple of weeks ago. I havent seen any of what is being talked about here...do I need to worry about anything, or is this just a nuisance? If I get this code, what happens? By the way, my setup was completely stock.
Old Aug 17, 2004 | 01:26 AM
The PO300 issue only affects a relately small portion of EVO owners. Chances are that you will never get it. So don't worry about it
Shiv
Old Aug 17, 2004 | 01:37 AM
thanks....i need more power mang!!!!
Old Aug 17, 2004 | 10:15 AM
cjb's Avatar
cjb
I PM'd you...
