Accumulators not work w/ progressive setup?
Old Dec 23, 2005 | 06:11 PM
bishiboy's Avatar
I've been considering adding an accumulator to my set-up to help lower the cycling of the pump.
My question is, if you have one and the pump pressurizes it, can you really have a progressive set-up?
I believe most progressive setups just increase voltage to the pump. ie..60psi of water at turn=on point (lower voltage) and 150psi at max spray (12V).
So, if the accumulator is pressuized to 150psi, could it react fast enough to correctly increase water pressure.
Am I correct on this?
Old Dec 23, 2005 | 08:22 PM
SlowCar's Avatar
wheres Richard when you need him most
Old Dec 24, 2005 | 01:17 AM
Richard L's Avatar
Hello Guys, I was in the midst of the dreaded Christmas shopping routine. I am glad to report, for this year, its all done.
Adding an accumulator to a pump speed progressive system is not possible. The accumulator will absorb any pressure changes - the very natural of the accumulator's job. If you are varying between 60psi to 150psi, your theoretical flow variation is only the square root of 2.5 (150/60), or only getting x1.58 overall increase in flow.
If you add an accumulator, the change in flow is almost non existant, based on the above example. I think if you want something that will give your true progressive to your engine's W/M requirement, you might consider investing on PWM solenoid set up, similar to a the principle of Fuel Injection. If you are interested, I can post some information here how to intergrate such a system into your current set up.
Richard
Old Dec 24, 2005 | 08:24 AM
bishiboy's Avatar
Richard,
Yes please do.
I like the idea behind Coolingmist's new programable progressive controller.
I think the more precise we can controll the flow the better the tune.
Right now I'm doing 90% of my tune on the ECU/fuel side.
I really like the Aquamist approach by using the fuel injector's dutycycle.
MR1JZ
Oct 12, 2016 08:03 AM
Richard L
149
Feb 27, 2016 03:01 PM
mrfred
58
Jan 4, 2016 06:09 PM
DetroitEvoIX
Sep 13, 2012 06:31 PM
Fast Frank
Automotosports - Illinois
15
Aug 27, 2011 10:33 AM
