Water injection and EGT
Old Jan 3, 2006 | 01:45 AM
gunzo's Avatar
Anyone gotten any correlation or data with spraying water and the EGT they are getting ??
I would assume that you'd get lower temps when you spray given the fact that ignition is advanced quite a fair bit
I'm getting around 880-920degrees C at the manifold side with no ignition advance ..
I've also found out overspraying can put out the fire in your car (literally) .. so make sure you're running a good ignition system !!
300cc at 1.8bar at 6000rpms = BAD misfire !!
Also due to bad plugs .. that's one of the reasons why I can only see about 2-3 degrees advance only !! (hopefully)
Old Jan 3, 2006 | 07:13 AM
SlowCar's Avatar
I never seen my egt rise above 900C with ~11 degrees at peak tq. Totally agree about the misfire! @17v/v% water to fuel. A ignition amplifier like the HKS DLI II or the COP(used by bishiboy) helps fix the problem. It helps to close down the spark gap too.
More timing advance-leaner burn(quicker burn), the combustion occurs within engine, not in the exhaust manifold.
Old Jan 4, 2006 | 01:06 AM
gunzo's Avatar
well I'm running the DLi .. yet I get misfires
at peak torque I'm (around 4500rpms) I'm seeing about 800C .. but at 7500rpms I'm seeing 920C or so .. at 1.7bar 11.2AFR with 17-18degrees advance timing
Old Jan 4, 2006 | 06:12 AM
SlowCar's Avatar
just curious....whats your spark gap?
Old Jan 5, 2006 | 05:49 AM
gunzo's Avatar
0.024 i think.. anyway it was the plugs lousy bpre8ix.. theres a lifespan to these buggers..
now with the new set of plugs i'm good
now trying to advance the timing to see if egts come down
ast
Aug 19, 2025 07:09 PM
supwiddiss
Aug 17, 2015 10:27 AM
Vivid Racing
13
May 27, 2007 02:45 PM
evolution6.5TM
Oct 28, 2005 12:14 PM
