SMC stock pump overloaded?
*** UPDATE*** 26Dec 2005
SMC company claims that the flojet pump fitted on the SMC alcohol/water kit are custom modified to handle the necessary demand pressure despite the rating of the pump labeling.
It caught my attention that the rating of the SMC kit pump says 35PSI(2.4 bars).
My system puts over 100PSI at the nozzle, I verified this by placing the pressure gauge one inch from the nozzle and inline with the alcohol steel line.
Anyway, being the pump rating at 35PSI don't you guys think that pushing 100PSI is a bit overloading on the pump?
If I am not mistaking the pump is adjustable via spring that adjust the contators and current flow in top of the pump..
Any comments?
Thanks!!
Any comments?
Thanks!!
Carlos,
I would call SMC directly and ask them what they think afterall they should know about the pump they put in the kit.
PJ......
Ps: get this someone jacked the badging off our mrs trunk last nite and scratched the hell out of the trunk
PJ......
I suggest to get it from the horses mouth, call Flojet to see if it is acceptable to exceed the stipulated rating by 3 orders of magnitude.............. My 0.2 cents
thats blows....is the paint work damaged???
Carlos,
PJ......
PJ......
I just can't believe someone did that to your car already. The lettering are about $18. I am really sorry to hear that. I have a spare lancer evolution badging, it is silver/chrome, just let me know, you can have it.
Carlos
From Flojet: Model LF122-202 Demand Supply Pump
http://www.flojet.com/prodInfo/overv...309B_11_05.pdf
The pump has an overload protection, the motor has a thermal-cut out switch so protects the pump but not sure at what temperature it cuts in.
The pump is listed as an intermittant duty cycle - but no other information regarding the load/temperature rise over time - the shurflo has published such a chart on their specification sheet.
I think most application is intermittant - I can't see you can be on boost more than 10 seconds at a time.
Richard
Richard
Originally Posted by GTVEVO
35psi is where the pressure switch is activated ontop of the pump. I think you are being mislead.
Flojet
Demand spray pump
LF122202
SN:XXXXXXXX
12VDC
4.0Amps
Flow:1.0gpm(3.8lpm)
Pressure: 35psi(2.4bar)
"The LF122202 pump with santoprene diaphragm and EPDM check-valve is designed to run water at a maximum pressure of 35psi. Tampering with the pump to run 100psi will result in pump failuer due to cracking of the pumphead....." Flojet - Engineering Support, (949) 859 4945.
I really hope you got a plan "B"
Originally Posted by Evo_Kid
Now to the thread, if the Flojet people say whats above, then I hope/think that SMC modified the pump to handle it. If not, I don't know why SMC would make a kit will a pump unable to handle the PSI.
http://www.flojet.com/prodInfo/overv..._189_02_98.pdf
The only modification i can see to make the pumphead take 3 times the designed operating pressure is MAYBE going to a fiberglass filled/reinforced polypropylene resin...........
