SMC stock pump overloaded?
Originally Posted by a post on this thread
...I'd prefer to have an all stainless, compact 150 psi pump, but then the kits would be $1,000 since a pump like that costs $500 IF you can find it.
Check this out for $39 *as a kit upgrade*, probably cant handle anhydrous denatured mixtures or esp MeOH and is huge, but this momma will probably atomize the solvent to clouds. As a failsafe you can tee before the nozzle and tie into the WS washer nozzle to keep the bugs of the glass.
I think the pump is only available as an "upgrade path" to the standard pump for an extra $39.00.
Richard
Richard
Originally Posted by C6C6CH3vo
http://www.snowperformance.net/prodd...p?prod=auto060
Check this out for $39, probably cant handle anhydrous denatured mixtures or esp MeOH and is huge, but this momma will probably atomize the solvent to clouds. As a failsafe you can tee before the nozzle and tie into the WS washer nozzle to keep the bugs of the glass.
EvilBlueEvo8
Aug 16, 2011 01:38 AM
Pure Playaer
45
Jan 19, 2008 07:38 AM
EvoTech
Jan 20, 2006 06:07 PM
EVO8LTW
17
Feb 8, 2005 07:57 AM
