what fitting to use off the i/c spray tank?
Old Jan 5, 2006 | 11:46 PM
nickracer9's Avatar
anybody know what fitting you can use coming off the hole where the i/c spray pump was? the hole is about 3/4 of an inch. btw its for a alkycontrol.com kit. thanks.
Old Jan 6, 2006 | 10:31 AM
nickracer9's Avatar
up
Old Jan 7, 2006 | 01:14 AM
nickracer9's Avatar
anybody?
Old Jan 7, 2006 | 11:44 AM
nickracer9's Avatar
theres a pic in this thread: https://www.evolutionm.net/forums/sh...t=ams+alky+kit
what is it?
Old Jan 7, 2006 | 04:00 PM
bishiboy's Avatar
I plugged mine with a 3/4" rubber bung, siliconed in. Then drilled a new hole for the brass fitting I used to feed the pump.
Also to note: if you take the clear overflow tube and wrap it up and around the filler neck, you can fill the resevior all the way up.
You can also just remove it and plug it, I'm just that lazy, but it also works as a view window to see how full the bottle is as you fill.
Old Jan 7, 2006 | 04:14 PM
nickracer9's Avatar
i want to use the hole thats in the tank already. you can see a pic of it in the thread i linked. I just don't want to worry about have 2 possible leaks. thanks.
Old Jan 9, 2006 | 06:56 AM
DSMotorsport's Avatar
1/2 pipe thread to 3/8" barb. if brass fitting, your going to need some teflon tape to make it seal. if using a plastic fitting, glue will seal it.
chetrickerman
Oct 20, 2015 07:10 AM
Steven_Trujillo
22
Oct 17, 2012 05:50 PM
badev0
Jun 4, 2010 04:21 AM
infini_IV
Nov 11, 2009 07:28 AM
JSYEVO
20
May 7, 2005 11:48 PM
