ARP Head Studs a Requirement?
Old Mar 29, 2006 | 08:56 PM
silex's Avatar
Just wondering if everybody who runs alky kits here put arp head studs on no matter what or if they wait and put them on later; but just run a lower boost setting.
Old Mar 29, 2006 | 09:28 PM
C6C6CH3vo's Avatar
I think the W/I systems don't really necessitate head fastener upgrade. RPM/HP levels dictate so.
We'll see once others chime in.
Old Mar 30, 2006 | 07:00 AM
TTP Engineering's Avatar
Meth actually lowers cyl pressure, however most usually run meth to bump up the boost and timing that increase it once again.
At about 375whp I would move to studs.
Old Mar 30, 2006 | 08:07 AM
newbieEVO8's Avatar
Cheap insurance if you want my .02
Old Mar 30, 2006 | 08:55 AM
C6C6CH3vo's Avatar
There you go, Methanol Injection doesn't directly require stud upgrade, but since HP drastically increases with it (WI), so does the force on the studs.
Old Mar 30, 2006 | 10:56 AM
silex's Avatar
Is there no difference between the VIII and IX studs? Would think with all the upgrades on the IX that they would include upgraded studs as well.
Old Mar 30, 2006 | 03:37 PM
UpstateEVOVIII's Avatar
I don't think studs are required if you are just doing injection...I'm going to do mine with my cams/valvetrain.
Old Mar 30, 2006 | 06:28 PM
C6C6CH3vo's Avatar
So would it be safe to asume that once your WHP hits 375, not to mention RPM at 8000 rod bolts, the studs become under termendous stress - more than stock ones can handle.
Old Mar 30, 2006 | 06:37 PM
poohlvhun's Avatar
not something I want to find out the hard way...
Old Mar 30, 2006 | 06:43 PM
vone750's Avatar
+1 gonna put the studs on to be on the safe side.
Old Mar 30, 2006 | 07:56 PM
Studs are a good pre-caution at any stage..but not a necessity til later
Old Mar 31, 2006 | 10:54 AM
EvilBlueEvo8's Avatar
so i guess they would be strongly recommended for an evo with 100% meth injection, 272's, boost control, etc (around 375-400 awhp) huh?
Old Mar 31, 2006 | 11:34 AM
flo2877's Avatar
just to be in the safe side you rather put them on. You dont know dont the road your stock studs dont hold the HP you got and they might give up. Thats more money now if something happens to your engine. Rather be safe than sorry.
Old Mar 31, 2006 | 12:35 PM
C6C6CH3vo's Avatar
Does the factory service manual provide sufficient data for the R/R procedure?
Old Mar 31, 2006 | 02:49 PM
No, 1x1 method is an unorthodox procedure that you will find acceptable no where.
We do it however along with many others.
asu11
Sep 6, 2016 07:31 AM
Sheasta
Oct 29, 2015 05:00 PM
EVO 4 life
Oct 26, 2015 08:11 PM
TampaTurbo
23
Oct 20, 2005 04:44 PM
evoland
Feb 25, 2005 11:41 PM
