Alky Injection-Yes or No?
Old Apr 14, 2006 | 07:19 PM
moto17's Avatar
Originally Posted by Fast Frank
I have decided at this point to not rush into anything, so I'm not going methanol right now-Looking into other options race gas, bigger turbo etc...
Thanks for the SNOW info i'll check into it!
go with a NON-PROGRESSIVE system and add the Aquamist DDS3. Nothing out there can touch this combo!
Old Apr 14, 2006 | 07:47 PM
Evo_Jay's Avatar
Yes.
I think the best way of running Alky is Shiv's new "lean protection" feature.
A quote from Shiv's post
1) Lean Run Protect
You define the leanest allowable on-boost AFR curve (5 RPM points) and decide how long it needs to be triggered for (0.5 sec is long enough to not induce false triggers caused by sensor lag) and let the XEDE do the rest. By "rest" I mean a sudden boost drop. If it still remains leaner than that threshold at the lower boost (say another 1 second), it'll do a hard fuel cut. The user can change the conditional logic (allowable time durations, actions, etc,.) This is critical for Methanol use where a pump failor or a jet clogging will destroy a motor in no time. Also good for protection in the case of fuel pump failure or anything else that could induce leanrun.
here's the link...
https://www.evolutionm.net/forums/sh...d.php?t=183252
Old Apr 19, 2006 | 01:28 PM
Fast Frank's Avatar
I'll have to rethink my Xede now hmmmm........
Old Apr 19, 2006 | 04:16 PM
Ultimate CC's Avatar
If you need any info on snow just let me know...
Old Apr 20, 2006 | 12:31 AM
SlowCar's Avatar
Originally Posted by Evo_Kid
Yes.
1) Lean Run Protect
here's the link...
Plus either snows or aquamist failsafe. makes it a "safer" system.
Old Apr 20, 2006 | 09:22 AM
SnowTech.3's Avatar
Our Safe Injection upgrade actually measures fluid flow and if it drops below a preset level, it triggers an output that can be used to operate a wastegate solenoid/boost controller or ignition retard etc. on a standalone.
Old Apr 20, 2006 | 07:13 PM
Hyper_Rev's Avatar
Very Nice
Old Apr 20, 2006 | 07:18 PM
When im not so busy I will post up a video of the failsafe in action
Old Apr 21, 2006 | 07:46 AM
Fast Frank's Avatar
Now were talking Failsafe! Awesome info -Keep it comin'!
Old Apr 22, 2006 | 03:15 AM
SlowCar's Avatar
I am building a Shurflo based 100% methanol injection system for a friend, will be using a 15GPH - 945cc/min jet and considering using the SI-10 unit.
What happens when the injector has a partial clog or a pump that is semi-working and the flow of injectant falls in the range somewhere between (6GPH - 378cc/min) and (15GPH - 945cc/min)?
tbryant0226
Dec 17, 2013 05:48 PM
scheides
271
Jan 6, 2013 10:06 AM
korndogg
For Sale - Cars For Sale
31
Oct 17, 2011 08:03 AM
hwy_ten
17
Apr 29, 2010 08:25 PM
IMPORTIMAGE
Oct 12, 2007 05:47 AM
