Alcohol Injection or Cams???
Originally Posted by archie001
y not both?
The reason why I think the cams are a better move is A. The lesser chance of them causing a catastrophic failure B. The amount of boost you would want to run to get the most out of the gains really isn't safe in my mind without head studs, but you will probably want to do that down the road anyway and C. The cams are something that you will always be benefiting from, and never have to continually waste cash on (in the form of alk)
Scorke
Originally Posted by fsugatorbait
99% of the people go with cams before alky. Id like to hear from Warrtalon on this one since he was tuned with an alky kit before adding the cams.
Originally Posted by flabarm
When you say a whole bunch of mods, do you mean like a fuel pump, or power mods? I already have a mbc, and the fuel pump and arp head studs are on order
Now i would say it really doesn't matter which one you get first. Do you have a tune already? Maybe BOV because sotcker leaks boost. Maybe 10.5 hotside (im not sure what year your car is)
+whatever for both
...i'd rock the cams first..take advantage of better flowing intake and exhaust gases..once used to that... slap in meth and now take advantage of lower intake temps...for increased timing ...and boost...cams and meth = "oh happy day"
