Need Answer Fast
Old May 23, 2006 | 06:15 PM
EvoTech's Avatar
Need Answer Fast
OK my alcohol injection pump has died for the 2nd time. (no I will not name brand b/c they are taking care of me) I am heading to the track tomorrow and I was wondering if it would be safe to run my meth map with 100 octane at say 26 psi. The alcohol kit is not in the car, so this will be on straght 100 octane. There is no time for me to create a new map so I was thinking about trying to run my meth map on 100 octane. Anyone try this before or know how 100 octane compares to meth in terms of knock resistance.?Thanks in advance.
Old May 23, 2006 | 06:43 PM
EvilBlueEvo8's Avatar
well for one, you're gonna run really rich till you get to the part of the fuel map where it was leaned out for the meth. what octane was the meth map made for? 93 octane? 91? also what percentage of alcohol was your mixture? if you were running 93 octance with 100% methanol, that is about 100 octane. it all depends on what setup the meth map was made for. its possible. can't say that is perfectly safe though. like i said before, it depends.
Old May 23, 2006 | 07:03 PM
EvoTech's Avatar
Thanks for the reply. My map was 100 meth with 93 octane. When you say 93 + meth is about 100 octane, how do you arrive at that. Just curious?
Old May 23, 2006 | 07:18 PM
i read it on here before. i'd search for you but i gotta go to bed cause i gotta go to work soon. i believe methanol has a octane rating of 140 and a stochimetric afr of 6:1. if you were to take the percentage of methanol to gasoline for a certain volume, you could figure it out. i'd really try to find that info out though if i were you. i wouldn't want to remember wrong and have it be someting like 104 octane, then you'd be running lean. just search for something like "93 methanol octane" and hopefully you'll find it. i believe it was in this particular forum. good luck.
Old May 23, 2006 | 07:23 PM
Blue Evo 8's Avatar
Thats a good question... cant you call a local tuner and find out?
I'm sure Sean Ivey, AMS, Buschur, TT, Pruven would know....
Old May 23, 2006 | 07:27 PM
EvoTech's Avatar
I am my local tuner, I just don't have time to tune a new map. I can always just run my pump map, but more boost would be nice at the drag strip tomorrow.
Old May 23, 2006 | 07:31 PM
Blue Evo 8's Avatar
Yeah I forgot... but maybe another tuner can give ya a second opinion ?
Old May 23, 2006 | 07:33 PM
C6C6CH3vo's Avatar
EvoTech- Just out of curiosity, were you running 100% methyl?
I'm starting to worry now that the tip of my idle motor is melted off (nobody take this info as if the two are related - yet).
Thanks
Old May 23, 2006 | 08:31 PM
SlowCar's Avatar
hmm.....just data log and see if you are knocking or running lean with 100oct@26psi. how big is your nozzle......m15?
Old May 23, 2006 | 08:34 PM
SlowCar's Avatar
btw do you know what is the cause of pump failure the last time and this time? this will be helpful info for fellow WAI user.
Ultimate CC's Avatar
what em are you running...
Old May 23, 2006 | 08:42 PM
DRFTKNGG's Avatar
Data log, if it's tuned on 93 and meth, you run 100 and meth at 26lbs, should run fat. See how close a/f are. Turn up the boost to 27-28 if data logging goes well, no knock.
This is where the knock light would come in handy.
Old May 24, 2006 | 04:35 AM
EvoTech's Avatar
Thanks
Interesting and yes I am running 100% but it would not "melt anything" but it is highly corrosive. Not sure why I am on my 3rd pump. The only thing that I do different than most is that I use it less often. I have a seperate meth map and I do not dial it up much.
Old May 24, 2006 | 11:35 AM
SnowTech.3's Avatar
Is your Meth reservoir in the engine bay or trunk? 100% methanol has a boiling point of about 150 degrees F which can cause vapor lock if it gets that hot.
car_nut15
Dec 11, 2011 08:24 AM
kmolleson
14
Sep 2, 2011 02:55 PM
DaGermanEvo9
26
Apr 5, 2011 09:08 PM
cij911
31
Aug 5, 2009 04:15 PM
Pure Playaer
45
Jan 19, 2008 07:38 AM
