View Poll Results: which should i use, ALKY OR METH
Alky
10
41.67%
Meth
14
58.33%
Voters: 24. You may not vote on this poll
alcohol vs meth
Old Aug 4, 2006 | 06:11 PM
Spoonierme's Avatar
alcohol vs meth
okay..so i've been reading alot of posts lately and it seems like there are several different opinions about the effects of using either alky or meth in the alky kits. And alot of people seem to be getting their facts mixed up.
so before i install my Snow performance kit, i would like to know all your opinions on what I should use..
here is my situation:
i have 05 gsr that has, 272 cams, TBE, headstuds, FP, electronic boost controler, and after the kit is installed a reflash.
now this is an important tid bit here. i take public transportation to work so my car sits pretty much from monday to friday without moving. That means that any chemical, whether its alky or meth, will be sitting in my car for a 5 days without much use.
I also will most likely be doing a 50/50 mix with windshield washer fluid. I am TRYING to hit 400whp or close to it on stock turbo (will upgrade in a year hopefully) but reliabilty is my priorty.
PLEASE help me choose between using alcohol or methonal.
any advice is greatly appreciated.
Old Aug 4, 2006 | 06:55 PM
SlowCar's Avatar
inject methanol, the more the better......make sure u got a failsafe to go with it. as long as there is no aluminum in your injection system and your system is fairly well sealed with a one way flapper valve( to prevent vacuum in resevoir) b/c MeOH is hygroscopic.
Next get a tuner who knows how to use the full benefits of methanol.
Old Aug 4, 2006 | 07:02 PM
EVOIXMR8916's Avatar
alky
Old Aug 6, 2006 | 03:27 AM
C6C6CH3vo's Avatar
bc
scheides
271
Jan 6, 2013 10:06 AM
scheides
15
Jul 25, 2008 06:39 AM
Pure Playaer
45
Jan 19, 2008 07:38 AM
tke_413
30
Mar 15, 2006 12:06 PM
PPI
Automotosports - Illinois
11
Jul 25, 2005 08:30 PM
