would i be able to hit enough boost?
Old Nov 8, 2006 | 12:01 PM
Rcebowl's Avatar
i'm getting the Buschur Alky Kit soon ... i'm also planning on picking up a GT35r
After looking around... i saw that the gt35r's sweet spot isnt until 30psi
would i be able to hit that 30psi with 91oct and meth?
Old Nov 8, 2006 | 12:23 PM
SlowCar's Avatar
also plan on a failsafe for the alky.
Old Nov 8, 2006 | 01:55 PM
C6C6CH3vo's Avatar
Snow has applications that use a 220 psi pump (Buschur 100psi) intended to atomize nicely at 60 psi boost
Old Nov 8, 2006 | 01:59 PM
Rcebowl's Avatar
wait soo alky injection more flow is more Oct?
Old Nov 8, 2006 | 05:24 PM
C6C6CH3vo's Avatar
I must have misinterpreted your question.
I thought you were looking for setup that still sprays decent mist beyond 28psi, boost levels you typically run.
But yes, more methanol is kinda like more OCt equivalent.
Anyhow, Al Friedman used the same Bushur kit on the 35 and 40 R, ask him what to run
Old Nov 8, 2006 | 06:38 PM
SlowCar's Avatar
Originally Posted by DynoFlash
A few points
Various widebands have different calibrations for different fuels
Also various fuels burn at different "ideal" ratios with air
When we are spraying alcohol in gas it is a hybrid fuel
The amount of alcohol used governs how rich the mixture should be
Generally you should run alcohol much richer than gas
I dont think Al is the person to ask for advice............
Old Nov 8, 2006 | 07:22 PM
C6C6CH3vo's Avatar
You must have dug that one up from the early alky days when ethyl alcohol was used - undenatured 98%
Old Nov 8, 2006 | 07:31 PM
SlowCar's Avatar
https://www.evolutionm.net/forums/sh...41&postcount=3
Old Nov 8, 2006 | 07:38 PM
C6C6CH3vo's Avatar
It was a joke, undenatured (everclear gulp gulp + keyboard)
Old Nov 8, 2006 | 09:32 PM
Rcebowl's Avatar
soo if he isnt who is? eh
Old Nov 8, 2006 | 10:17 PM
gogoevo's Avatar
if you have good failsafes then i would say def yes, whoever you pick to get a kit from i would hope could give you a good idea of how much to spray(dont you think?)
