Another alky injection project
Old Feb 8, 2007 | 10:36 PM
  #106
SlowCar's Avatar
no accumulator.....i need to put one in tho, got one of richards pump with a accumulator - the water comes out of the nozzle pulseless!......u'll see the video in a day or 2.
Old Feb 8, 2007 | 10:59 PM
  #107
EvoTio's Avatar
The new pump set up sounds great. If my pump ever goes bad, I'll upgrade to his new one. So far I have about 5 trouble-free years and counting on my current Aquamist pump.
Old Feb 9, 2007 | 07:24 AM
  #108
SlowCar's Avatar
that certainly speaks a great deal about the quality of these aquamist units!
Old Feb 9, 2007 | 09:18 AM
  #109
EVO8LTW's Avatar
I don't think it would be an "upgrade" to go from the magnetic piston pump to a Shurflow pump if you don't need the extra capacity, would it? I was under the impression that the shift to the Shurflow pumps was to get a lot more capacity for a reasonable price (versus, say, dual magnetic piston pumps). The offset is that the durability of the pump probably isn't as good (more friction internally) and it's a lot larger and heavier.
Old Feb 9, 2007 | 12:36 PM
  #110
EvoTio's Avatar
It was more of a thought that if my current pump ever needed replacement, I would would upgrade to the Shurflow for the extra flow capacity. I figured if I needed that extra flow for a future project, it would be there. But you're right about the offset, so I may think twice when that moment arrives to replace the pump. So far my current Aquamist pump is hanging in there and has never overheated even after back to back 1/4 mile runs.
Old Feb 18, 2007 | 06:11 PM
  #111
SlowCar's Avatar
Project completed
Old Feb 18, 2007 | 07:03 PM
  #112
Evoryder's Avatar
very clean Mr. Slow
Old Feb 18, 2007 | 07:47 PM
  #113
SlowCar's Avatar
Mucho gracias Evoryder.
Old Feb 18, 2007 | 07:55 PM
  #114
Evoryder's Avatar
6 injectors, 2 fuel tanks, 3 fuel pumps...i got one on ya lol
What numbers are you doing?
Old Feb 18, 2007 | 08:04 PM
  #115
SlowCar's Avatar
you working on a redundant alky system with 2 shurflos?
2 weeks ago, i was contemplating a intercoolerless system with 8 injectors, 3 fuel tanks and 2 fuel pumps - decided against it b/c i think the car will look like crap having a 2.5" tube running across instead of an IC........4 injectors for the intake tract
Old Feb 19, 2007 | 07:36 AM
  #116
Evoryder's Avatar
not redundant at all..very effective
Old Feb 19, 2007 | 09:43 AM
  #117
SlowCar's Avatar
So you will run both together or have the spare one kick in when low flow/pressure is detected?
Old Feb 19, 2007 | 10:34 AM
  #118
Evoryder's Avatar
they run in tandem...primary nozzle 225ml/min, secondary nozzle 175ml 100% meth.
Intake temps are much lower with the 2 pump/nozzle vs 1 ...better cooling acroos cylinders...
Old Feb 19, 2007 | 04:13 PM
  #119
SlowCar's Avatar
have you got a pic of your setup?
Old Feb 19, 2007 | 05:25 PM
  #120
Evoryder's Avatar
i already posted them in this thread...all the pix i got....i can draw a diagram in paint of how it works
