SMC Methanol Users
Old Dec 29, 2006 | 04:30 PM
fishing_ndw's Avatar
SMC Methanol Users
How long should it take to reach greater 100 psi when I hit the test button? Mine is currently taking about 5 seconds or more. I think I have a problem .
Old Dec 29, 2006 | 04:33 PM
cfdfireman1's Avatar
This happens every time you test it?
Old Dec 29, 2006 | 05:03 PM
itzwolf's Avatar
Well I was having an issue with my pressure not going over 75/80psi. SMC quickly and painlessly replaced the pump on my kit. After installing the new pump same thing first test 80psi, second test 40psi, then after that the gauge stops reading any pressure, but the kit is working properly. The gauge is cheap and it *could* be the gauge is faulty as well. I'm going to look into another gauge, cause the kit is spraying a ton of fluid...
Old Dec 29, 2006 | 05:10 PM
hova00's Avatar
That is a sign of pump failure friend. Mine will see 100psi very quickly. On my G/F rex it would take longer so sent the pump in to have it replaced. Steve is great to deal with.
Old Dec 29, 2006 | 06:43 PM
SlowCar's Avatar
Old Dec 29, 2006 | 06:49 PM
BoostWhore's Avatar
how old is ur kit?
Old Dec 29, 2006 | 09:09 PM
itzwolf's Avatar
Did a little tuning on my car tonight using AEM EMS and the SMC kit. Using a dyno.mth the graphing registers a 100HP increase and the car feels like a freak. Should hold me over till I get it on the dyno to get more power extracted...
Old Dec 29, 2006 | 09:45 PM
fromWRXtoEVO's Avatar
Wait a minute guys! why T--shoot to a faulty pump? it is too early to make speculations. A broken/loose line would consequently make the system to loose pressure.
Perhaps and obstructed line would potencially cause similar effect. He must check the lines first and make sure there is no obstructions nor openings.
Always remember the analogy of the water/fluids/liquids and the electricity, they act in similar ways when it comes to flow.
Carlos
Old Dec 29, 2006 | 09:52 PM
4G63 T's Avatar
Speaking of which:
Im leaking!! The BLACK RUBBER HOSE connecting from PUMP to RESERVOIR i tried tighten the silver clamp to no avail, HELP.
Old Dec 29, 2006 | 10:04 PM
Originally Posted by 4G63 T
Speaking of which:
I know exactly what your problem is, now let me ask you this:
Is it leaking because of the clamp is overstressed and is no longer clamping with enough force? or is it leaking because the rubber hose is cracked/broken?
In the first case just replace the clamp for a stronger one.
On the second case replace the hose, it should be like a 3-4" long hose.
In both cases the fix is fast, cheap and reliable.
Carlos
Old Dec 30, 2006 | 02:26 AM
4G63 T's Avatar
The latter, clamp very tight i cant even diassemle it.
but i will as soon as i get back from vac. any recommendation where to get durable replacement.
thanks.
Old Dec 30, 2006 | 03:39 PM
fixem2's Avatar
I have the same issue and replaced the hose and clamp to no avail. I believe there is a crack in the casing near the output port and where the casing meets. I can see alky coming out of the area after a few test button hits and it will still come out with the vehicle off.
Old Dec 30, 2006 | 03:45 PM
cij911's Avatar
I sure want to get a Meth / ALK kit, but it seems a lot of people have serious issues with their setups and the only ones that don't have problems are on professional / mechanics / guys that are always tinkering with their cars...
Old Dec 30, 2006 | 03:49 PM
1NastyEvo's Avatar
Just have it installed by a professional and try and watch them do it. Get a slight idea of how it works. You won't have any problems.
Just check on it every now and then.
It's not rocket science bud
Old Dec 30, 2006 | 03:51 PM
fixem2's Avatar
Just an FYI, this is the first problem I have had and I have had the kit for 3 years. I would not discount this kit it works well.
