coolingmist varicool ( does it work )
Please take some time to read this thread and pass comment
http://www.rx7club.com/showthread.php?t=616563
Scott
Scott
"It does't need to. Take Aquamists "high flow" pump. Its rated at 125 psi. Do you think its any better? Before you answer, I have one sitting on my test bench.
Shortly we will have a pump available that will not pulse, it will be a larger high pressure pump with a bypass built in by the factory." Coolingmist
If it is not needed, why are you following/copying the by-pass concept aquamist is using?
Some innovate, some just plain ole copy!
Just for the record... the answer you never got..
Hello Slowcar,
I have managed to retrieve the following deleted post by David of Coolingmist at the RX7 forum... in the original form !!!
Good for you, I dont care. Shurfo told us we are the first methanol injection company that they private labeled a pump for.
I have a few question for you..
theres a shock.
Gee Richard I dont know. Maybe when I went to PRI and saw a company that makes spark plugs and they had a competitors spark plug in the display and they showed the difference between the two.
maybe we are tesing our smart injection unit against your high flow system as we speak.
maybe none of the above.
2) R&D or copying?
We dont need to copy you.
3) Why are you using "Aquamist" as an "Ad word" on your google sponsored link?
I dont know, but since our Smart Injection unit with the flow gauge is going directly against your Highflow system with DD3s, I think we will add DD3S to the Adwords. Infact if I get around to it I will do it later.
4) Do you have no shame?
I dont care what you like or dont like. There is nothing illegal or unethical about using a competitors name as a keyword. We are not the only one doing it. We were the ONLY one that offered to remove it if the industry does the same.
All you ever do is go around and bash other systems that are not aquamist, that are progressive. Not everyone can afford a $25,000 system. We have a system coming out shortly that is going to cost less and do more than your high flow system, so get used it.
David
Originally Posted by Richard L
wow...
David of CM...
I like to add, Shurflo has been supplying custom pumps to us from factory way before year 2000, using EPDM valves and seals and with by-pass valves... while you were still figuring out how a relay works in 2003, some years later.
If you don't believe me, here is the proof:
http://www.rx7club.com/showthread.p...71&page=3&pp=15
David of CM...
1) What are you doing with our pump on your test bench? !!!
2) R&D or copying?
David
The above link posted by Sdminus has very good technical contents and backed up with facts. Still, a large part of the discuss remains.
This is the first time someone has done an in-depth study of such a concept.
If you buy two, I will give you one for free
Originally Posted by SlowCar2
Richard, you are way to nice to educate these WAI kit makers that just slap parts together!
When i first started out playing with WAI, 2 companies i contacted for technical questions, aquamist and coolingmist.
Coolingmist: i asked questions about what size nozzles i should use on my mitsubishi evolution, he blew me off and told me, "unless you buy our system, i am sorry i cannot help you"
Aquamist: I asked Richard technical questions, he was out to help he all he could even i havent bought a single part from him!
Me and a few of us WAI users on EvolutionM are really appreciative for the technical help, some of whom are not aquamist users!
It really shows who is in it to promote the art of WAI and who is in it to make a quick buck.
my 2 cents
my 2 cents
Originally Posted by coolingmist
complete BS and you know it.
David, no reason for me to
Howard, this thread is not supposed to be an Aquamist Public Relations thread. Its supposed to deal with the issue at hand which nobody seems to want to REALLY solve. Its just meant for one reason and one reason alone...so Slowcar and other AM fans can continue to bash my company.
You’re only seeing 1 thread. I got at least 10 threads bookmarked where he pulled this b.s. with me.
Honesty Coolingmist does know jack .... About cars and only has a basic understanding of how alcohol injection works. He just has a very good background in b.s. and sales.
I am one of the owners of devilsown water Injection. I even don’t' know everything when it comes to alcohol/water injection. I have seen him make claims that just defy the laws of physics. I call him out and he just points out my rotten spelling. I always look at his tech is like the blind leading the blind. I have a arch background and Richard has an eng background so I guess that’s why we don't seem to have any problems grasping.
Alcohol injection not that difficult but so much false info has been passed around. I spend a good portion of my day trying to correct the misinformation. I get dam near 100 emails a day. Good portion of it is just common b.s. marketing of coolingst. Is this how you fell richard?
Originally Posted by moron at devilsown
Depending on the age of snows pump its liable to have viton valves. Vs having mtbe in the alkycontrol pump. If your going to run the straight 100% meth i would use alkycontrols pump. I am not 100% sure when they started getting custom pump 3-4 months ago that they switched over to mtbe or buna.
You also use fittings designed for AIR at a max temp of 140F and very low pressure. You did this because they are cheap. Yet you claim they are made for water and high pressure. You want me to link everyone to where you buy them? Let me know I'll be glad to.
All your company does is try to bash me.
I dont have to point out your spelling. you have no concept of how to develop a good product (or a half decent sentence structure for that matter). You also have no concept of what it means to run a company. Your false claims from something you posted on line many months ago has been elevated up the corporate ladder to a legal department (not from us), so hopefully soon if they follow through you will learn a good lesson.
I believe people can spot BS a mile away and you are plenty visible. You attack me left and right, I have told you many times I would leave you alone if you did the same with me, but you dont seem to understand that concept.
You wanna hit me? go ahead, i'm going to hit you back twice as hard from now on.
... Alcohol injection not that difficult but so much false info has been passed around. I spend a good portion of my day trying to correct the misinformation. I get dam near 100 emails a day. Good portion of it is just common b.s. marketing of coolingst. Is this how you fell richard?
I don't like mixing engineering matters with unsubstantiated claims.
Richard
David, an example of your materials knowledge:
Your IC sprayer tank should be methanol compatible. Shurflo is the name of our pump. Our pump is 100% compatible with methanol when sold with any of our controller based kits (including the commander kit). Our seals are EPDM which can handle over 300F and Pure Methanol. Most of the kits you see on the market have VITON seals that cant handle more than 50% methanol.
Thanks!
Thanks!
