Tank/Pump Placement Question
Old Feb 2, 2007 | 03:25 PM
SlowCar's Avatar
Originally Posted by EvilBlueEvo8
so back to my original question.....having the pump even with the bottom of the tank is best??? would make sense.
put it anywhere you can fit it..........
Old Feb 2, 2007 | 03:35 PM
Evoryder's Avatar
Originally Posted by jbrown
What???
I originally had my pump mounted in my trunk...clean install...however, one day it decided to siphon overnight...i went to start my car in the morning ...cynlinders had meth in them...dealer thought I sucked up water and hydrolocked the engine...drained the system...new starter...problem fixed...now i'm just paranoid about having it in the trunk due to that.
engine = heat
Trunk = cooler
...meth/water works better if fluids are cool vs warm/hot
Old Feb 2, 2007 | 04:01 PM
Evoryder's Avatar
one of my 3 setups.
1)
2)
Old Feb 2, 2007 | 04:02 PM
Evoryder's Avatar
3)
Old Feb 2, 2007 | 04:04 PM
Evoryder's Avatar
dual stage works...can't wait to tune more aggressively...
Old Feb 2, 2007 | 05:10 PM
SlowCar's Avatar
how big are your 2 jets?
Old Feb 2, 2007 | 05:14 PM
Evoryder's Avatar
175ml LICP
225ml TB
Old Feb 2, 2007 | 05:18 PM
SlowCar's Avatar
~6.35gph
nice
u got headstuds?
Old Feb 2, 2007 | 05:27 PM
Evoryder's Avatar
headstuds are for suckers lol...
Cam installation is when the studs go in
only 24psi 4 me
Old Feb 2, 2007 | 05:32 PM
SlowCar's Avatar
24psi even after HS?
Old Feb 2, 2007 | 05:37 PM
Evoryder's Avatar
probably crank it up to like 27/28psi and tune around that ...
Old Feb 2, 2007 | 05:40 PM
SlowCar's Avatar
someone is going to make some serious torque
Old Feb 2, 2007 | 05:42 PM
fromWRXtoEVO's Avatar
Originally Posted by SlowCar
~6.35gph
nice
u got headstuds?
Abner,
how did you do the conversion rate? Are we assuming it is ml/hr?
Carlos
Old Feb 2, 2007 | 05:44 PM
SlowCar's Avatar
1 gph = 63cc/min
Old Feb 2, 2007 | 05:47 PM
1 gph = 63cc/min
That is all good but on the equation he left one missing parameter(time).
Carlos
