Tank/Pump Placement Question
Evoryder,
Your set ups are good, it shows you have a lot of imagination however I think the one set up on the trunk perhaps would be more appropiate concealed on the little rear left quarter panel compartment.
What do you think? did you tried it?
Carlos
Carlos
Abner(SLOWCAR), Your ex-Evo8 is slow,trust me!!! my poor 8!! it needs some water injection and it will be fast again
thought about it ...i'll probably end putting it back in the trunk(rear quarter)
If you read the post from the guy( he just said 225ml and 175ml) you have to guess the minutes or hours. As far is the conversion rates, Cmon Abner, I work all my lifes with US and metric..
Carlos
LOL, Abner, I was shocked when I saw your ex-car in front of me today(your car was on the dealer for about one year), I don't know if Mitsubishi dealer ever found out you had a 2.4l block, regardless of all the mods it once had and all the big displacement it was dead meat for my GSX today, I know I can't talk much about racing so I will change the subject(I must be discrete).
Carlos
Carlos
...i'll look into it.
email pix: sk8tull@yahoo.com
I originally had my pump mounted in my trunk...clean install...however, one day it decided to siphon overnight...i went to start my car in the morning ...cynlinders had meth in them...dealer thought I sucked up water and hydrolocked the engine...drained the system...new starter...problem fixed...now i'm just paranoid about having it in the trunk due to that.
engine = heat
Trunk = cooler
...meth/water works better if fluids are cool vs warm/hot
engine = heat
Trunk = cooler
